93 wrangler nv3550 swap question - JeepForum.com
post #1 of 13 Old 09-01-2013, 12:27 PM Thread Starter
Cory1980
so i bought my first jeep a few months back. a 93 wrangler I6 with a 5speed. after 3 days of riding in it with a big smile on my face the trans blew a part.... now for the really bad stuff. it turns out that the previous owner put a peugeot in it. yes im sure. i asked questions, looked up numbers and looked at pics. so i get in the market for the right trans that should be in my jeep and DANG!!! they are hard to find and when you do find one the price...... anyways so i start looking into going to the nv3550. there is a local junk yard that may have one with the t-case out of a 2001 cherokee for a good price. i plan on going to take a look at it in the next couple of days. from everything i have read it should be as close to a bolt in as you can get. my question is is there anything that i should be worried about doing this swap? anything that yall know will help alot. again this is my first jeep/jeep part swaping. i know my way around tools and can do a good hack job at welding ;-) . i just need to know if this is something i should really look into. thanks in advance!
Cory
Cory1980 is offline
post #2 of 13 Old 09-01-2013, 09:47 PM Thread Starter
Cory1980
any info would be great.
Cory1980 is offline
post #3 of 13 Old 09-02-2013, 01:14 AM
Jeepsr4me
Post pics of the bad trans. I am pretty sure the drive shafts are not same length when going from the ba10 to ax15
Jeepsr4me is offline
post #4 of 13 Old 09-02-2013, 03:08 AM
timatoe
timatoe's Avatar
I'd have to ask if you're absolutely sure it's a BA and then ask for pics as well based on this from Novak.....
Originally Posted by Novak Conversions
The Jeep BA10/5 is only found against the AMC 258 I6. It has a unique front bolt pattern that is not a match to any other Jeep bellhousing or transmission.
Here's some more info on the BA10, the AX-15, and the NV3550.
timatoe is offline
post #5 of 13 Old 09-02-2013, 08:45 AM Thread Starter
Cory1980
here is the trans and motor.
Cory1980 is offline
post #6 of 13 Old 09-02-2013, 08:46 AM Thread Starter
Cory1980
Cory1980 is offline
post #7 of 13 Old 09-02-2013, 01:04 PM
Doch80
Don't know about the BA but the only modifications I did when I installed my nv3550 was to the floor pan and the trans shifter bracket. I used the same throw out bearing and all.
_______
/I ,[_____],
IóL --[]IIIIII[]--
()_) ()_)-o-()_)
Doch80 is offline
post #8 of 13 Old 09-02-2013, 01:31 PM
czjeeper
You'll need to re-clock the t-case if the setup came from an XJ. Re-drill the holes in the trans.
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out!
czjeeper is offline
post #9 of 13 Old 09-02-2013, 03:52 PM Thread Starter
Cory1980
the setup im looking into is from a 01 cherokee. if i get everything from bellhousing to tcase is there anything i need to be aware of like electrical/computer stuff? from what all i read up on my jeep is supposed to have the ax15. so the nv3550 should be bolt in so to say right?
Cory1980 is offline
post #10 of 13 Old 09-02-2013, 04:55 PM
timatoe
timatoe's Avatar
That's certainly a BA10.
I think you'll basically bolt up.
timatoe is offline
post #11 of 13 Old 09-02-2013, 09:47 PM Thread Starter
Cory1980
kool. im going to go and look at it this weekend. maybe its all there so i can get my jeep back on the road. im aboit to give up on finding me a jeep replacment and go chevy. i can find them almost everywhere.....
Cory1980 is offline
post #12 of 13 Old 09-03-2013, 08:50 AM
Doch80
It'll basically (should) bolt up but you will have to make a few modifications. The opening in the trans tunnel on your floor board will need to be opened up b/c the shifter is positioned further back and you'll need the clearance. You'll also need to make another cover to compensate for the larger opening. Not a big deal as everything you need is at Lowes or Home Depot.
You'll also need to figure out what to do about the transfer case shifter. I bought a bracket that bolts to the TC at the tranny mount. You'll also need to modify your TC shift linkage possibly. Again not a big deal. Totally worth it in my opinion
_______
/I ,[_____],
IóL --[]IIIIII[]--
()_) ()_)-o-()_)
Doch80 is offline
post #13 of 13 Old 09-17-2013, 08:00 PM Thread Starter
Cory1980
well my luck is no good like always. the trans is gone oit of the jeep i was looking at. however a buddy of mine has two 80's chevy that he will sell me so i will just do a conversion. one is a 4 speed the other is auto. which is going to be my better choice? as far as i can tell everything else is about the same.
Cory1980 is offline
