'93 Wrangler Codes - JeepForum.com
post #1 of 9 Old 10-06-2008, 03:36 PM Thread Starter
Kman1983
1983 CJ5
'93 Wrangler Codes
We've been having a problem with my wifes '93 Wrangler,2.5, 5 speed for about a month now. About a month ago it died acting like it wasn't getting fuel. I replaced the fuel pump and fuel filter. It started but again died while driving down the road. After checking the codes and getting some ideas from the board I changed the crank position sensor(ckp) and the coil. It fired right up and I went for a test drive. Hit a bump and it died. It finally started up and I hit another bump and it died. It restarted but was sputtering and hesitating awful and died again. Let it set and it fired up and ran fine and I drove back home. It died pulling in the yard. It refired but was sputtering and wouldn't go over 1700 rpm.I shut it off let it set a minute and refired it and it ran OK. As it was idling I got out and wiggled a bunch of wires and unplugged the map sensor which caused it to run rough and I plugged it back in.I shut it down and restarted it and it ran fine. I checked the codes:12(my step son helped himself to the battery the other day),33(I have no idea it doesn't have AC),11,14(I unplugged the map sensor),54,15 and of course 55. Does 54 mean the cam position sensor is bad in the distributor? If so the sensor(the pick up stator?) is $68. from NAPA and a remaned distributor is $72.50....I'm a little lost as what to change next...any thoughts?
Kman1983 is offline
post #2 of 9 Old 10-06-2008, 05:23 PM
Mobile_Homie
Desert Rat
Mobile_Homie's Avatar
Just a shot in the dark....have you done any wiring or mods under the jeep?? Look for a loose wire touching the exaust somewhere. That sounds just a lil too intermittent to be throwing sensors at it. . Happend to me Happy Wheelin'
Mark
Smoke em if you got em!
Mobile_Homie is offline
post #3 of 9 Old 10-06-2008, 05:37 PM Thread Starter
Kman1983
1983 CJ5
We did a complete frame swap in June/July and added a lift kit and new body mounts with a 1" lift built in. I'll climb under it and take a look to see if a wire could be hitting. I cleaned all the grounds on the engine when we hooked the wiring back up. It ran fine until early September then the gremlins started coming out.
Kman1983 is offline
post #4 of 9 Old 10-12-2008, 05:47 PM Thread Starter
Kman1983
1983 CJ5
At the moment it will crank over but not start. I removed the cap on the shrader valve on the fuel rail and pressed the stem down and fuel barley trickled out. It's got a new fuel pump and I tried replacing the fuel pump and auto shutdown relays. What am I missing????
Kman1983 is offline
post #5 of 9 Old 10-12-2008, 05:52 PM
Burnerman
Burnerman's Avatar
The fuel filter is good? How is the cat? Maybe it broke apart and has the exhaust clogged? That's all I can add to what has already been said.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #6 of 9 Old 10-12-2008, 06:19 PM Thread Starter
Kman1983
1983 CJ5
I installed a new filter when I installed the new fuel pump. Not sure on the cat but I do have a problem with it not pumping fuel.
Kman1983 is offline
post #7 of 9 Old 10-12-2008, 07:22 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Key to the problem is the YJ running poorly every time it hit's a bump. It sounds electrical in nature. I do believe that all those sensors noted in the DTC's you named have a common ground at the PCM.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #8 of 9 Old 10-13-2008, 05:23 PM Thread Starter
Kman1983
1983 CJ5
I'll check the ground. That could sure be it. Interesting side note: I installed the new relays and it wouldn't start. When I reinstalled the old relays it fired right up...
Kman1983 is offline
post #9 of 9 Old 10-13-2008, 06:18 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Check for corrosion in the relay sockets also, you never know.
I think the ground that is common for allthose rlays goes back to the ECM also. It may be pin 4 but I am not absolutely sure.
92 Wrangler computer codes 12 33 and 55 Bowfin YJ Wrangler Technical Forum 5 09-10-2009 05:43 PM
FAQ - Check Engine Light and Diagnostic Trouble Codes (Error Codes, Problem Codes) Wheelin98TJ TJ Wrangler Technical Forum 6 05-15-2009 06:05 PM
89 wrangler - Does it have engine codes? tawdr77 YJ Wrangler Technical Forum 4 08-06-2008 10:53 PM
2007 Wrangler paint codes BillArf JK Wrangler Technical Forum 7 05-03-2007 07:55 AM
reset error codes on 93 wrangler??? REDMANYJ YJ Wrangler Technical Forum 1 04-09-2004 09:06 AM
