93 surges when driving - JeepForum.com
post #1 of 6 Old 06-16-2013, 02:21 PM Thread Starter
quarterback4
I have a 93 wrangler straight 6 that surges when driving, I have replace the fuel filter. and the injectors, and plugs and new wires and rotor, still having problem. Any help?
quarterback4 is offline
post #2 of 6 Old 06-16-2013, 06:32 PM
superj
Ecu temp sensor is good? Is there a map sensor on the fuel injected models? I don't remember from when my wife had a 93. The fuel pressure is holding good?
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #3 of 6 Old 06-17-2013, 06:21 AM
UZI4U
Pull off the throttle body and use a can of carb cleaner on it. Make sure to use a new gasket when you put it back on. If it persists, you might try a throttle position sensor.
MCLMM
UZI4U is offline
post #4 of 6 Old 06-17-2013, 08:58 AM
92BlackandBlue
Mine was doing this exact same thing, ended up being the throttle position sensor. One of the most annoying things to deal with.
92BlackandBlue is offline
post #5 of 6 Old 06-17-2013, 02:30 PM
idaholtby
Please check for codes, while not all problems on OBDI can be picked up, it is the first place to start. Beyond that, if no codes, then check fuel pressure at the rail using the Schrader valve. Rent a tester from a part house if need be. Check pressure at idle and again with the vacuum line removed from the fuel pressure regulator. Reinstall the vacuum line and then shut her down. Continue to monitor the pressure over time and see how much it bleeds down if at all. This info will give us a good point to start with to help you solve this issue. This may not show any good info, but at least many things will be ruled out.
idaholtby is offline
post #6 of 6 Old 06-17-2013, 04:22 PM Thread Starter
quarterback4
Thanks I will try these, no code comes up.
