93 Sahara 6 cyl 49,000 Miles / Help with Small surface rust spot - JeepForum.com
post #1 of 6 Old 11-16-2009, 08:20 AM Thread Starter
loggy
I have a 1993 Sahara, 6 cyl, manual 4.0 with only 49,000 miles. It is in excellent condition with a couple exceptions. At the bottom of rear quarter I have a small surface rust area in and around the fender lip. Since the Jeep is all original I want to keep it that way with a minimum amount of sanding/paint work.......What is the best approach ? I had heard of some type of rubberized coating perhaps for the bottom 1" area ? Any help would be appreciated.
loggy@mindspring.com
Les
loggy is offline
post #2 of 6 Old 11-16-2009, 08:43 AM
Jeepsr4me19
1976 CJ5
Well you got to get the rust gone. If its surface rust sand it till its all gone then treat it with something like navel jelly to get rid of any you didnt see. Then get a self etching primer and treat the metal. Follow all directions on cleaning the surfaces. Once the primer is dry you could coat with any paint or rubber coating. You just got to get all rust 1st. Leave any or try to coat over it and you will have a night mare on your hands in a short time.
Got any pics of the rusted area?
Jeepsr4me19 is offline
post #3 of 6 Old 11-16-2009, 11:29 AM Thread Starter
loggy
Sahara
I did just take a couple pics..please send me your e mail and I will forwrsd. THANKS !
Les
loggy is offline
post #4 of 6 Old 11-16-2009, 11:45 AM
Jeepsr4me19
1976 CJ5
Get you a photobucket.com account. Post them there and then paste the links in a reply here. Its free and makes posting pics super easy.
post #5 of 6 Old 11-16-2009, 12:22 PM
Fhajad
You live in Ohio with only a tiny bit of surface rust!?
You're one of the lucky ones.
Fhajad is offline
post #6 of 6 Old 11-16-2009, 12:43 PM
Jeepsr4me19
1976 CJ5
Rust whats that? Is that something like snow. I hear alot about it but never get to see it...........
Small surface rust.. MarshallUJeep TJ Wrangler Technical Forum 1 04-14-2009 12:44 PM
Turns out that surface rust was more than surface rust... ss454 YJ Wrangler Technical Forum 11 04-01-2009 04:36 PM
Surface rust Straight6 TJ Wrangler Technical Forum 5 04-07-2008 05:37 AM
Surface rust on hinges vpogv TJ Wrangler Technical Forum 2 01-16-2004 03:15 PM
spot/surface rust on my frame zband TJ Wrangler Technical Forum 2 09-01-2003 07:45 AM
