93 half door problems - JeepForum.com
post #1 of 11 Old 02-22-2010, 10:04 AM Thread Starter
Obcean2
Please help. My half doors have had issues since I got the jeep 2 years ago. I thought it was the lock cylinder, but now I think it is the latch/lock mechanism. I discovered this when I tried to shut the door and the mechanism on the door would not latch around the post on the door. I have done several searches on the internet and several other jeep forums as well as this one (of course!). I have checked all the Quadratech and 4Wheel Parts. I can't find the replacement mechanism, period. I am sure they are available at the stealership, but I would like to avoid that. I read a few posts about components being bent and thus easily fixed, but I am not clear on what was bent in the first place because no one posted pics. Has anyone seen a write up on this issue? Is anyone familiar with how to fix/replace the parts in the door, and what probably needs to be replaced after 17 years? Please help. I would rather fix whatever might be broken, but a supplier other than the dealership for replacement parts would be great to know about. Thanks!
Obcean2 is offline
post #2 of 11 Old 02-22-2010, 10:28 AM
warhog-06
Make sure the latch is bad first. You should be able to push the latch in with a screwdriver, just as the post would. If it will close and lock, it is probably just an allignment issue. The doors, and the striker (post) can be adjusted.
warhog-06 is offline
post #3 of 11 Old 02-22-2010, 11:11 AM Thread Starter
Obcean2
Thank you. I suspect it is an alignment issue, but I just don't see how to make the adjustments. Any ideas?
Obcean2 is offline
post #4 of 11 Old 02-22-2010, 07:40 PM
warhog-06
A torx bit should fit in the end of the striker. You loosen it just enough to be able to move it around. The closer you move it to the door, the further out the door will stop. The further away from the door, the tighter it will fit. Usually, after hitting it a few thousand times the striker will move back far enough that the door will shut hard or not latch at all. Try to move it toward the door, a little at a time until it shuts easily.
If you don't have the torx bit, you can sometimes use a set of channel locks/ pliers to lossen and tighten it.
post #5 of 11 Old 02-23-2010, 12:09 AM
Machine1582569
make sure your door handle is releasing fully. the rod that actuates the latch lever can sometimes seize up... Get some good penetrating oil and soak everything down. Pull your inner door skin and lube er up
1993 Jeep Wrangler S 4" military wrap lift with 5/8" Shackle lift. 32x11.5x15
Machine1582569 is offline
post #6 of 11 Old 02-23-2010, 09:09 AM
1Aauto
Vendor
1Aauto's Avatar
If the latch assembly is getting stuck. Apply some white lithium grease to the moving parts,this will help to free it up.
You can buy it at any auto parts store.
1Aauto is offline
post #7 of 11 Old 02-23-2010, 09:26 AM
YJames90
YJames90's Avatar
I just installed a set of hard doors last weekend and had the problem of the doors not latching shut
I had to unscrew the striker and put some washers behind it so it extended out further. You can also move it up or down before tightening for proper alighnment
My 2.5 to 4.3 swap thread
YJames90 is offline
post #8 of 11 Old 02-24-2010, 06:47 AM
YjMick
The striker can be adjusted with a T50 torx, also you may need to adjust the lower body hinge by loosening it while door is open. Then close the door, and if it closes fully, retighten the hinge while the door is closed
YjMick is offline
post #9 of 11 Old 02-24-2010, 11:55 AM Thread Starter
Obcean2
Awesome! Thanks so much for the help. We soaked the mechanism for a day in lithium grease and that helped a lot. We also moved the striker pin forward. So far, so good. Now that I have working doors, I am going to work on the tailgate. That has to be the same issue. It is a good thing that I procrastinate, because I was planning to remove the lock cylinders and have them serviced somehow, and maybe rekeyed. Now that is money I can spend somewhere else on the yeep!
Obcean2 is offline
post #10 of 11 Old 02-24-2010, 12:15 PM
1Aauto
Vendor
1Aauto's Avatar
Glad we could help out a fellow Jeepa.
1Aauto is offline
post #11 of 11 Old 02-24-2010, 01:06 PM
YJames90
YJames90's Avatar
nice !!!!!!!
YJames90 is offline
Upper half door problems moe1954 TJ Wrangler Technical Forum 4 11-17-2009 05:20 PM
fiberglass upper door half problems MoTownYJ YJ Wrangler Technical Forum 0 09-22-2009 11:05 AM
Will TJ half door panels fit on a YJ half door? shinerm02 YJ Wrangler Technical Forum 0 07-02-2009 09:41 PM
half door problems jeepindirty TJ Wrangler Technical Forum 7 06-05-2006 06:39 PM
Where to purchase half upper half door absentiabanish TJ Wrangler Technical Forum 3 04-11-2005 08:26 AM
