93 ABS...How are is it to get rid of it? - JeepForum.com
post #1 of 2 Old 02-06-2013, 02:05 PM Thread Starter
cburgin
I may be buying a 93 that has the abs option. I am going to be swapping to tons and 37s so the master cylinder will need swapped as well. Is ditching the abs a job?
cburgin is offline
post #2 of 2 Old 02-06-2013, 02:54 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
not really since you'll be swapping master cylinders too. just run all new hard line.
just remember to read up on brake systems. a larger master will require a larger booster along with it to build the correct amount of pressure. i'd just suggest going straight to hydroboost and call it a day.
ratmonkey is offline
