93 4.0L sounds like a diesel - JeepForum.com
post #1 of 28 Old 04-19-2010, 03:07 PM Thread Starter
dudeinajp
dudeinajp's Avatar
I'm just curious if this is normal. The PO says the bottom was rebuilt w/ new oil pump about 10k ago, 110,700 on it now. He did it because of the gauge reading low and inconsistent and not being familiar with the 4.0L. It was reading the same after the rebuild as well. Changed out the sender, same. He put a mechanical gauge and it was reading good and steady oil pressure. I want to know if all is okay and not have to worry about it. I've had other 4.0L Jeeps, but none sounded like this one. It runs great though.
Here are a couple of vids.
dudeinajp is offline
post #2 of 28 Old 04-19-2010, 05:59 PM
MoparFreak69
Almost sounds like piston slap to me. The reason I dont think it is rod knock is when you revved it the noise went away. Usually rod knock will get louder and louder with more revs (just went through this with a Neon I had). Its a bit hard to tell from the audio but that is my thought. Take a long screwdriver and place the handle into your ear and touch the metal end around to various spots on the block. Use it as a stethescope. Its the quickest and easiest way to figure out where the noise is coming from.
90 YJ 5.2 Magnum, AX-15, 231 SYE'd
D44 front, welded/trussed AMC20HD rear. 4.56 gears soonish.
Western 6 lug aluminum wheels, with 35x12.50x15 Wrangler MTRs
MoparFreak69 is offline
post #3 of 28 Old 04-19-2010, 06:10 PM
1stockjeep
1993 XJ Cherokee
Its the lifters. My g pas wrangler is the same way. They most likely are gummed up and dirty. The right way to fix em is to replace em. But you can run half a qaurt of atf ( yes I said atf) or marvel mystery oil to clean em up. The atf is high in detergents and will help clean em up. You would be suprised the diff it makes. You can also use sea foam but I kinda worry bout putting something thin as water in my oil. Run it for a few hundred miles and go easy on it. If ya gonna pull loads or hills AI would put fresh oil in first
1stockjeep is offline
post #4 of 28 Old 04-19-2010, 06:33 PM
jeep_maniack
i heard that SeaFoam is supposed to help sticky lifters... i used it in my jeep and it seems to be running smoother.. people told me it helped their sticky lifters so if it is the lifters then maybe this will help. just search seafoam how to on youtube maybe even add in jeep to the search and you will see what i mean..
Any questions PM me and ill try to help as far as sea foam goes.
Good luck! later
..l_______
./l ,[_0_0_],
.l----L -[]lllllll[]-
()_)=o()_)=o=)_)__-_-__-__-_-___
jeep_maniack is offline
post #5 of 28 Old 04-19-2010, 06:45 PM
1stockjeep
1993 XJ Cherokee
I have done the sea foam in the intake. Make sure ya have a breezy day lol! It makes some smoke
post #6 of 28 Old 04-19-2010, 07:41 PM Thread Starter
dudeinajp
dudeinajp's Avatar
I'll give this a shot. I just changed the oil w/ some 15w40. If it doesn't work, I'll just have the head I have rebuilt before I pull the old one to replace the lifters and I assume the cam as well. The exhaust manifold needs replacing too, cracked, so I'll just do it all at once. As long as it will get me through until next spring, I'll deal with the noise.
post #7 of 28 Old 04-19-2010, 07:46 PM
Louie4
Welcome to my world. Mine sounds just like yours and has been sounding like that for years. I'm at 296k miles but it runs great. A little noisy but I can't justify tearing it down when it runs so good. I've tried thicker oil and mystery marvel. Nothing helped.
Me and my buddy just replaced the cam, lifters, timing chain, and had a valve job done on his 258 4.2L and it's so quiet. I was jealous.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #8 of 28 Old 04-19-2010, 07:55 PM Thread Starter
dudeinajp
dudeinajp's Avatar
That's why I tried the 15w40 oil and it didn't do anything. The MMO may not either, but it's worth a shot.
post #9 of 28 Old 04-19-2010, 08:21 PM
1stockjeep
1993 XJ Cherokee
The thicker oil may not help because the lifter is plugged and the oil cant get in. I ahve seen these things run for long time makin all kinds of noise! Buy a loud stereo. Thats what i did
post #10 of 28 Old 04-19-2010, 08:36 PM
Louie4
$4 for the MMO. Definitely worth a shot. I try to use it every other oil change. As a matter of fact I put the larger oil filter on and increase the oil capacity a little.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #11 of 28 Old 04-19-2010, 08:39 PM Thread Starter
dudeinajp
dudeinajp's Avatar
I turn the stereo up too.
I didn't think of using a larger filter. I'll have to remember it for next time.
post #12 of 28 Old 04-19-2010, 08:47 PM
Louie4
At Autozone it was right next to the STP S16 filter (one called for in the book). I think its an S8. I don't know how much it really did for me but it didn't hurt.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #13 of 28 Old 04-19-2010, 08:59 PM
JFranko
Sound's like Jimi Hendrix to me
I'd say lifters, when I changed mine it made that sound (except only once lifter was hitting). I just took the valve cover off and ground down where it was hitting to give it a hair of extra clearance. I'd recommend changing them before you go that route though.
Also, good pick on getting the YJ
1992 YJ Wrangler 4.0L, NV3550, 2.5" suspension lift, 32" BFG M/Ts, lots of other cool stuff
RED JEEP CLUB MEMBER #494
JFranko is offline
post #14 of 28 Old 04-19-2010, 09:14 PM Thread Starter
dudeinajp
dudeinajp's Avatar
I have an extra block and head that came with the Jeep, he was going to build a Stroker. I think I'll do the same. A budget 4.5L since the funds are and will be tight.
Thanks. I love the YJ. It's much more fun than any of my previous XJs or the ZJ I sold to buy it.
post #15 of 28 Old 04-20-2010, 09:17 PM Thread Starter
dudeinajp
dudeinajp's Avatar
After closer inspection. The sound is at its loudest where the engine/transmission come together. I'm going to change the fluid in the transmission to see what happens.
98 4.0L sounds like diesel. Is it bad? studioj TJ Wrangler Technical Forum 7 03-21-2010 10:52 PM
4.0 sounds like a diesel??? abeshures TJ Wrangler Technical Forum 16 12-12-2008 03:35 PM
my 2.5 sounds like a diesel brewer YJ Wrangler Technical Forum 20 05-16-2006 07:47 PM
my '03 5sp sounds like a diesel... hangar18vfr TJ Wrangler Technical Forum 9 10-30-2002 01:22 AM
4.0 sounds like a diesel rickr YJ Wrangler Technical Forum 14 11-30-2001 06:07 PM
