93 4.0L with foam in radiator - JeepForum.com
post #1 of 7 Old 02-15-2012, 05:35 AM Thread Starter
RUBE1975
Hey all first post and I could really use some advice. I noticed yesterday my engine wasnt getting hot and I got no heat. When I got into work this morning I touch the radiator cold, engine not strangely warm, checked the radiator and It was full of foam? And oil was clean at the dipstick. I let it sit a bit while I hit the internet looking for answers. Now I just went to check the head gasket. I noticed the foam had turned back to coolant when I opened up the radiator. Started the engine and got some bubbles and then the foam. FML
I got a could of questions
Does this sound like it could be anything else beside the head gasket?
anyone happen to know what am I looking at for cost to fix the head gasket vs replace the engine?
Any good shops between Canton MA and Somerville MA (boston area)?
Any good junk yards between Canton MA and Somerville MA (boston area)?
can I drive it home today without making the problem much worse?
What would you do in my shoes??
Thanks in advance for the help all.
RUBE1975 is offline
post #2 of 7 Old 02-15-2012, 06:01 AM
Louie4
If you're engine is running cold and you have no heat it sounds like you need to replace your thermostat. Was the foam oily or just foam? I say get a thermostat, flush the cooling system, refill and let it run. Then check for leaks and see if the heat works.
If you're running into the same issue report back.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #3 of 7 Old 02-15-2012, 06:12 AM
Siva283
Sounds to me like you should check for other leaks first before jumping to the expensive stuff. Fill it up with collant too it sounds like it is really low. You may want to check the water pump as well. All that is free or cheap to check compared to 5 or 6 hundred to have a head gasket done or a few grand for a new engine. Just take a breath and start with simple and free and work your way up. But first fill it up with coolant all the way. Then start these test.
Ask me how I know...
Siva283 is offline
post #4 of 7 Old 02-15-2012, 06:17 AM Thread Starter
RUBE1975
Thanks for the advice Lou and siva it would def make my day if this isnt a head gasket. The foam is very clean ie not brown-ish in the slightest so thats a plus.
RUBE1975 is offline
post #5 of 7 Old 02-15-2012, 06:34 AM
dodger889
You can only hope it is just a head gasket and not a cracked head or block. But has was said try add coolant first. Then check it for bubbles and if you have bubbles with the engine running smell what is coming out. If it smell like exhaust then you have to look farther to find where the problem is.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #6 of 7 Old 02-17-2012, 10:52 AM
craniumboy
Any news about this?
Keep on Jeepin' on!
craniumboy is offline
post #7 of 7 Old 02-21-2012, 04:26 AM Thread Starter
RUBE1975
Thermostat failed open.
RUBE1975 is offline
sea foam liquid or sea foam deep creep?? HAMM YJ Wrangler Technical Forum 2 06-22-2008 10:03 PM
sea foam Q and A............. wegotj TJ Wrangler Technical Forum 38 07-29-2007 01:51 AM
Sea Foam ........? Josephrk24 YJ Wrangler Technical Forum 35 01-07-2006 06:19 PM
Sea Foam! A1C Toves YJ Wrangler Technical Forum 4 10-16-2005 12:48 AM
Sea foam jeepin1995 YJ Wrangler Technical Forum 10 07-02-2005 11:42 PM
