92 yj valve cover gasket do i need RTV? - JeepForum.com
post #1 of 14 Old 09-12-2011, 12:36 PM Thread Starter
02grandy
02grandy's Avatar
i have the 2.5L with the aluminum valve cover bought the local fel pro gasket i think its a blackish cork so i need to use any RTV anywhere? i see the plastic valve covers say to use it but cants find anything on the aluminum. thanks
02grandy is offline
post #2 of 14 Old 09-12-2011, 12:42 PM
chris142
Shouldn't need any sealant if you prep both surfaces correctly
chris142 is offline
post #3 of 14 Old 09-12-2011, 12:42 PM
91BoD
A thin layer wont hurt
91BoD is offline
post #4 of 14 Old 09-12-2011, 12:48 PM
jeepguy85
1987 YJ Wrangler
I always put a thin layer on the valve cover side. I don't worry about the head side as much. Not leaked yet.
Originally Posted by Exparrot View Post
"When Chuck Norris drives, Chuck Norris controls the radio..."
Originally Posted by HurricaneRZA View Post
Mean Max created Chuck Norris with some spare parts, two trac bars and some differential fluid.
jeepguy85 is offline
post #5 of 14 Old 09-12-2011, 01:16 PM
bigbossd1030
Not needed
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #6 of 14 Old 09-12-2011, 06:23 PM
Cooter92YJ
Sorry to hijak your thread, but where do you get an aluminum valve cover for a 2.5? Are they better than the plastic ones? Thanks in advance
Cooter92YJ is offline
post #7 of 14 Old 09-12-2011, 06:52 PM
bigbossd1030
They are better quality than plastic. Check quadratech or 4wd.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #8 of 14 Old 09-12-2011, 11:46 PM Thread Starter
02grandy
02grandy's Avatar
books says plastic rtv and aluminum use gasket.ok guys but it says 44 inch pounds which is like 4 foot pounds. i usually go by hand but dont want to under tighten it or over. any ideas?
02grandy is offline
post #9 of 14 Old 09-12-2011, 11:47 PM Thread Starter
02grandy
02grandy's Avatar
my torque wrench does 5lbs maybe just use that ..............
02grandy is offline
post #10 of 14 Old 09-12-2011, 11:55 PM
lclark2074
i userly put rtv on the valve cover side only so i can remove the vave cover without changing gaskets next time.
night crew 226
lclark2074 is offline
post #11 of 14 Old 09-13-2011, 12:48 AM Thread Starter
02grandy
02grandy's Avatar
i just put alittle so it would stick the valve cover when i when i dropped it down on the head. they are tightened snug now but i guess im gonna go with 5 foot lbs
02grandy is offline
post #12 of 14 Old 09-14-2011, 01:13 PM Thread Starter
02grandy
02grandy's Avatar
so the previous guy used black rtv i guess high temp but whatever and it only stuck to the valve cover and not the head. it was leaking 360 ...i used the right gasket and no leaks so far. do it right or dont do it at all..............
02grandy is offline
post #13 of 14 Old 09-14-2011, 04:06 PM
Alabamaranger
i also to put rtv on the valve cover side only to hold it in place. Otherwise it might get out of posistion and leak when installing. Old techs put grease on the opposite side so you can reuse it again. I use to do that on oil pan gaskets - RTV them to the block and put grease on the oil pan side. Old race car trick is to coat gaskets on both sides (to hold it in place and to reuse it again) with heavy grease, just a light smear. They will seal fine and are easily removed and reused that way without damaging them.
90 YJ, 4.2 with 2150 carb 4.0 Head and headers, Nutter with TFI and MSD. 1" BL, 2.5" spring lift, 33", Goodrich KM Mud Tires. Dana 30 w Aussie, Ford 8.8 w LS. 9000lb HF Winch.
Alabamaranger is offline
post #14 of 14 Old 09-14-2011, 04:36 PM
projectsahara11
I am not too familiar with using rtv put I don't see what it could hurt to put it on there. If you do it correctly you won't have to take off you valve cover for a good long while right?
projectsahara11 is offline
Valve Cover Gasket sequel YJ Wrangler Technical Forum 13 10-07-2009 08:08 PM
valve cover gasket TxYJ YJ Wrangler Technical Forum 10 06-09-2007 09:29 AM
Valve cover gasket TxYJ YJ Wrangler Technical Forum 2 06-02-2007 02:03 PM
2.5 valve cover gasket bob082484 YJ Wrangler Technical Forum 6 04-03-2007 07:07 PM
valve cover gasket damian H YJ Wrangler Technical Forum 3 10-15-2006 10:49 AM
