92 YJ transmission noise - JeepForum.com
post #1 of 27 Old 10-30-2009, 12:32 PM Thread Starter
deeincitti
Hey all,
Looking for some feedback on my problem.
I have a 92 YJ 2.5L 4Cyl with the AX5 transmission and when in neutral and clutch released(up position) and at idle I hear and feel a rumble/grinding. When I push in on the clucth it goes away. But, when coasting in neutral with the clutch released this noise does not happen. What could this be? I am thinking it's the throw bearing, but wouldn't the noise still happen when I am coasting in neutral as well? Thanks all
deeincitti is offline
post #2 of 27 Old 10-30-2009, 01:33 PM
MJMPC
Have you checked the oil level in your trans ?
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #3 of 27 Old 10-30-2009, 01:38 PM Thread Starter
deeincitti
No not yet. I will be doing a fluid change this weekend, but if that is not the case then what else could it be?
Deryck
post #4 of 27 Old 10-30-2009, 01:52 PM
MJMPC
Deryck
Could be bad bearings in the trans .
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #5 of 27 Old 10-30-2009, 01:58 PM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
I agree, could be your input shaft bearing.
5.7YJ is offline
post #6 of 27 Old 10-30-2009, 02:19 PM Thread Starter
deeincitti
Only happens in neutral when at a dead stop and idle. Every other senario does not produce the sound. (eg. while in gear and moving, in neutral while moving or coasting). I guess the only thing to do is check the fluid levels. If that doesn't work then it defenetly needs to come off anyways. I just want to be prepared if I do have to take it off.
Actually it is due for a replacement or rebuild anyways. Almost 300,000kms on it and I do believe everything is original on the transmission. LOL!! This jeep has been very, very good to me with respect to my bank account even though I beat the crap out of it
post #7 of 27 Old 10-30-2009, 02:23 PM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
It's amaizing you've gotten that many miles out of an AX5!
5.7YJ is offline
post #8 of 27 Old 10-30-2009, 02:37 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
I'm inclined to think throwout bearing. The fact that you can't hear it/feel it while coasting in neutral might be caused by just being distracted by the other things associated with a moving vehicle.
Definitely do an oil change on the gearbox and pay close attention to the fluid quality/condition of the old fluid, but my money still rides on the throwout bearing.
What oil are you planning on putting in the tranny?
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #9 of 27 Old 10-30-2009, 02:40 PM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
Your name looks good in green Max, matches the tag!
5.7YJ is offline
post #10 of 27 Old 10-30-2009, 02:41 PM Thread Starter
deeincitti
I am starting to feel lucky about it. Ever since I have been looking into this problem all I have been reading is how weak and crappy the AX5 is. Yes it may be weak, but the engine is pretty weak to boot. So they compliment each other pretty well There were issues with my AX5 ever since I purchased the jeep 5 or 6 years ago(eg. syncro problems and just being really noisy), but this is the first problem where I am actually concerned about the AX5 breaking down and having to do some work to it. If it is a bearing then it won't take long for that bearing to disintegrate I know that much. I will probably top up fluids and drive it until it needs replacing. It will be a good work out for my clutch leg at a red light.
post #11 of 27 Old 10-30-2009, 02:42 PM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
Do a fluid change like Max said and pay attention to the old fluid, it should tell you a lot.
5.7YJ is offline
post #12 of 27 Old 10-30-2009, 02:48 PM Thread Starter
deeincitti
Max
The noise this thing is making could not go unnoticed by other things happenning while moving while coasting. Believe me!! LOL! But I will definetly take it into concideration for sure.
I am thinking of putting Pennzoil Syncromesh in the tranny, but someone had told me just to use a 80/90 gear oil. What do you think?
post #13 of 27 Old 10-30-2009, 02:49 PM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
Don't AX5 transmissions use ATF?
5.7YJ is offline
post #14 of 27 Old 10-30-2009, 02:52 PM Thread Starter
deeincitti
I don't think so!?!?! The Haynes book says 75/90 GL. But I am open to suggestions.
post #15 of 27 Old 10-30-2009, 02:56 PM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
Sorry, I must be thinking about the T5 Ford tranny.
5.7YJ is offline
Noise from near Transmission jeepyjpsu YJ Wrangler Technical Forum 1 02-15-2010 03:42 PM
Transmission noise yj jordan TJ Wrangler Technical Forum 2 12-17-2008 11:16 PM
Odd noise from transmission cajun_jeep YJ Wrangler Technical Forum 4 07-05-2008 06:15 PM
Transmission Noise?? jeepfury YJ Wrangler Technical Forum 3 08-29-2005 11:02 PM
Transmission noise? MichaelJames TJ Wrangler Technical Forum 3 10-22-2004 06:16 AM
