92 YJ shuts off when in neutral - JeepForum.com
post #1 of 4 Old 07-08-2010, 10:01 PM Thread Starter
ortiz2188
plz help !!!!
i have a jeep wrangler 92 5sp manual with 4.0
my jeep will turn off by it self i will be driving and i'm about to stop in a light and hit the clutch to go to neutral and it will shut off but only in neutral if i hit the clutch in gear it will stay on
does any body have a idea ???
ortiz2188 is offline
post #2 of 4 Old 07-08-2010, 10:14 PM
MJMPC
Check your codes see if you get anything.
OBDI Error/Check Engine Codes - JeepForum.com Community Jeep Wiki
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #3 of 4 Old 07-09-2010, 06:35 AM
Que89YJ
Check the fault codes. Get underneath and check the wires that run along the shifter underneath. The have been several Jeepers who have had trapped wires for the fuel pump and VSS that short when the shifter was moved.
Que89YJ is offline
post #4 of 4 Old 07-09-2010, 07:26 PM Thread Starter
ortiz2188
haha!!!
guess what is not doing it any more but i still what to check the codes and the cables going underneath
thank you very much for the help
Shuts down in run position. bella mia YJ Wrangler Technical Forum 8 03-24-2010 09:33 AM
Jeep shuts off. What to do? ssl90 TJ Wrangler Technical Forum 3 03-16-2010 08:28 PM
Just Shuts Off coachparker44 YJ Wrangler Technical Forum 12 12-27-2009 07:33 PM
90' 4.2 shuts off on it's own montanamanone YJ Wrangler Technical Forum 1 09-11-2009 01:51 PM
91 yj shuts off rkg1275 YJ Wrangler Technical Forum 4 07-11-2006 12:12 PM
