92 yj shock question - JeepForum.com
post #1 of 3 Old 08-30-2014, 09:28 AM Thread Starter
Sk71
I am in the process of going through the suspension of a jeep I recently purchased. The po was running skyjacker 7088's on the rear and 7059's on the front. Is there any reason why I wouldn't want to run run 7088's all the way around?
7088's are for 2.5-6 inch lift
7059's are for 3.5-4 inch lift
Currently set up as soa with what I believe are stock springs needing a rebuild.
Thanks.
Sk71 is offline
post #2 of 3 Old 08-30-2014, 10:44 AM Thread Starter
Sk71
Looks like That combo is for a 4" lift. Now to confirm that's what's on it.
Sk71 is offline
post #3 of 3 Old 08-30-2014, 04:49 PM
sprngrider
You should compress and extend all four corners, one at a time, without the shocks installed. That will allow you to properly measure for the shock lengths that you need
1994 2.5L WRANGLER S.
sprngrider is offline
