92 yj rear pinion seal - JeepForum.com
post #1 of 5 Old 11-15-2005, 07:58 PM Thread Starter
headkase
Mines leaking, am I going to have to disassemble the whole rearend(remove pinion) to replace this seal?
headkase is offline
post #2 of 5 Old 11-15-2005, 09:07 PM
cjist1
cjist1's Avatar
Mine leaks also. I was just going to post this same question. From what I can see it looks like all you have to do is drop the driveshaft, then remove the pinion nut, then replace the seal. But Im not sure. I just looked at an exploded veiw of the dana 35 axle...thats what Im basing this assumption on.
92 YJ 2.5L 5 spd.
75.6hp/100.0 ft,lbs.
cjist1 is offline
post #3 of 5 Old 11-15-2005, 09:15 PM
JFM626
JFM626's Avatar
Do a search for "pinion seal removal" There are some very good writeups there.
JFM626 is offline
post #4 of 5 Old 11-15-2005, 10:41 PM
paintguy
I had a pinion seal leak in a '91 4.0 YJ that I had and I just drained and replaced the diff. fluid with 100% Lucas Oil and it didn't leak when I sold it after 2 1/2 years.
paintguy is offline
post #5 of 5 Old 11-16-2005, 06:53 AM Thread Starter
headkase
got it thanks.
headkase is offline
Rear axle seal/ Rear Pinion seal phillies4752 TJ Wrangler Technical Forum 17 02-01-2010 11:05 PM
D44 rear pinion seal vs. NP231 transfer case seal thejafe TJ Wrangler Technical Forum 14 06-14-2009 02:24 PM
Rear pinion seal TMJeep TJ Wrangler Technical Forum 5 05-12-2007 02:57 PM
Where to get rear D44 pinion pinion seal? Lud04X TJ Wrangler Technical Forum 2 02-22-2007 11:36 AM
Rear Pinion Seal RKSchmidt TJ Wrangler Technical Forum 4 10-13-2006 07:45 PM
