92 yj rear main seal replacement Q - JeepForum.com
post #1 of 8 Old 10-10-2007, 05:40 PM Thread Starter
BRAX
hey guys
just got a killer deal on a YJ, the rear main seal is pissing pretty good, prolly a quart a week, anyways, do i need to drop the tranny and clutch? or do i need to do the 2 piece way by pulling just the oil pan?
thanks!
also anyone have any ideas for a hard cold start? fires/turns over 3 times or so when cold to start, when hot it starts/catchs in 1-2 turns, thanks "maybe comp is getting low"
p.s. just did new plugs, checked the rotor caps and wires, new fuel filter as well.
BRAX is offline
post #2 of 8 Old 10-10-2007, 05:44 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
This would be easier to answer if we knew what motor you have in there.
See the sticky at the top of the YJ section regarding filling out your UserCP.
Now that being said (hoping you go fill it out), Short answer, 4banger= pull tranny to do it, 6 banger is a drop the pan and do the two piece deal.
your starts sound normal to me.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #3 of 8 Old 10-10-2007, 05:47 PM Thread Starter
BRAX
sorry bro! heh 4.0! im update'n my profile as we speak
BRAX is offline
post #4 of 8 Old 10-10-2007, 05:49 PM
rustywrangler
In that case, just drop the pan and do the 2 piece seal.
post #5 of 8 Old 10-10-2007, 05:51 PM Thread Starter
BRAX
oh man that sounds so much nicer than pulling the tranz! )
i need to do the rear transfer output seal as well, it has its own oil correct? "dosent share with the tranz"
looks pretty ez, does it have a drain hole to refil and check fluid level?
thanks bro!
1992 islander 4.0 5 speed
BRAX is offline
post #6 of 8 Old 10-10-2007, 08:20 PM
kloppk
thanks bro!
The two piece replacement is still tedious and messy.
Be sure to use a BRASS punch (not steel) when removing the old upper seal.
Get yourself a 1 piece pan gasket for the re-install.
Be sure to put the seal in with the correct front to back orientation or it'll leak.
Carefully follow the application of liquid soap, RTV and crank oil in just the right spots for
a trouble and leak free job.
Tcase uses ist's own lube. Actually it's Mercon III ATF fluid. The Red stuff.
The tcase has a fill and drain plug on the back of it - drivers side.
kloppk is offline
post #7 of 8 Old 10-10-2007, 08:22 PM
kharmajavah
For the 4.2 - same general idea: http://www.neow.org/rms1.html
For the 4.0 on an XJ - http://jeepin.com/features/rearmain/index.asp
p.s. - forget the motor mount removal in the 4.2 write-up. My Jeep is a stock set-up, and all we had to do was pull the pain and the rear main bearing cap. Supposedly it helps to loosen the next couple of caps to let the crankshaft drop a tad - helps in getting the top part of the seal out.
Just don't **** up like I did and put the top half in backwards...
...hangover mistake...
kharmajavah is offline
post #8 of 8 Old 10-10-2007, 08:29 PM Thread Starter
BRAX
awesome help guys, thanks so much
BRAX is offline
2.5 rear main seal Replacement Gonewhln YJ Wrangler Technical Forum 4 04-14-2009 01:27 PM
?'s about rear main oil seal replacement bob082484 YJ Wrangler Technical Forum 12 04-30-2007 12:15 PM
rear main seal replacement 87 alienball YJ Wrangler Technical Forum 0 06-01-2006 12:17 PM
Rear Main Seal Replacement PolloLoco TJ Wrangler Technical Forum 8 03-28-2006 08:12 PM
Rear main seal replacement TellyDSP YJ Wrangler Technical Forum 9 04-25-2005 10:24 PM
