92 YJ Rear Brake Lights not working??? - JeepForum.com
post #1 of 22 Old 09-20-2010, 12:22 PM Thread Starter
t2timmy
My rear lights work as well as the backup lights but when I step on the brake pedal the brake lights don't come on (rear lights stay on but brake lights don't come on). Checked/changed bulbs and checked all fuses and connections, even replaced the control switch on the pedal for when you release the brakes. Can anyone think of a reason why everything but the brake lights work??
Thanks.
t2timmy is offline
post #2 of 22 Old 09-24-2010, 08:21 AM Thread Starter
t2timmy
Anyone ever encounter this problem??
I still cannot figure out whats wrong... electronics suck!!
t2timmy is offline
post #3 of 22 Old 09-24-2010, 08:27 AM
MJMPC
Do your 4 ways work?
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #4 of 22 Old 09-24-2010, 08:43 AM Thread Starter
t2timmy
Good question... Just went out and tested them and they all work except the left rear... I pulled that working bulb and replaced it with another working bulb and it still didn't work. Checked that left rear connector (in the quarter well) again and still no worky. Funny how the right rear is blinking with the hazards on, and I mean that it stays lit with the parking lights and then get's brighter (like brake lights being applied) when the hazards are on.
t2timmy is offline
post #5 of 22 Old 09-24-2010, 08:47 AM
MJMPC
Did you replace the brake light switch?
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #6 of 22 Old 09-24-2010, 08:53 AM Thread Starter
t2timmy
Yes I did. The pedal switch with the button that is depressed once you step on the pedal. Someone on another forum said his 87 Cherokee had two types of switches on the pedal... I didn't see 2 and this is a YJ, but I may double check that.
t2timmy is offline
post #7 of 22 Old 09-24-2010, 09:26 AM
MJMPC
Did it look like this? Click on the pic to make it smaller.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #8 of 22 Old 09-24-2010, 09:49 AM Thread Starter
t2timmy
Yup that's it. Put a new one in and still same issue.
t2timmy is offline
post #9 of 22 Old 09-24-2010, 10:25 AM
MJMPC
Ok follow the wires up to where you pluged them in. Then go to the next connecter and make sure it is pluged in tight.
Do you have AC?
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #10 of 22 Old 09-24-2010, 10:28 AM Thread Starter
t2timmy
OK, that's my next test. I'm gonna buy an inline tester and do that too. I appreciate your help. I was hoping maybe it was a common issue that someone can point directly too. NO A/C in the jeep.
t2timmy is offline
post #11 of 22 Old 09-24-2010, 11:23 AM
remmons
The brakelight system also runs through the turn signal switch. Verify that power is running TO your brakelight and turn signal switches. Start from the source, the fuse block, and check the components and connectors as you move back. How do the ground wires look at the housings? Corrosion can sometimes break the electrical pathways.
Robert.
remmons is offline
post #12 of 22 Old 09-24-2010, 12:06 PM Thread Starter
t2timmy
I'm gonna rip into it more tonight. Really, through the turn signal switch? That sounds odd because when a turn signal goes out the brake lights still work? Either way, I'm gonna start from the fuse block like you suggest and the work my way back.. I doubt it's one one of the wires running down the frame rail but who knows.
t2timmy is offline
post #13 of 22 Old 09-24-2010, 02:08 PM
remmons
Yes. The power runs through a single wire from the fuseblock, which is controlled by a switched source (your ignition switch), to the brake light switch, it then runs as a single wire to the turn switch assy. where it divides into the left and the right circuits. When the turn signal is operated, it momentarily interrupts the power in a cycling action to the turn signal bulb(s), thus the blinking.
Robert.
remmons is offline
post #14 of 22 Old 09-24-2010, 02:35 PM Thread Starter
t2timmy
Ok didn't know that. Great knowledge, I thank you sir.
Hmmm then could that lead to an issue in the steering column wiring??? Sadly enough I'm on my second steering column because the old one broke at the tilt mechanism. I replaced it a couple of years ago and all lights were fine including the brake lights. But it came loose again last year and I had to take off the steering wheel and part of the column again to re-tighten the bolts. Ever since then whenever I turn hard to the right and then go to straighten out the wheel the horn beeps itself.... rather funny whenever I turn into a road on the right it beeps and people stare at me, or when you pull into a gas station with hot chics in the car in front of you it works to your advantage ..... could the problem be in the steering column blinker lever or something??
t2timmy is offline
post #15 of 22 Old 09-24-2010, 02:43 PM
Rproject
1987 YJ Wrangler
The left rear not coming on doesn't surprise me that much. Every 6 months or so I need to pull my left rear light assembly and clean the contacts. The seal on the housing is terrible and I get insane corrosion on the left rear contacts. I'll either lose the front left or back left turn signal which is a clue to me to crack it open and clean the contacts.
It took me quite a bit of time to figure out that this was the problem because it kept coming back again and again. Many of the symptoms you describe were present with me as well. A good solid cleaning of the contacts front and rear and the system started working again. Now I pull it all apart whenever my left side turn signal stops working, clean it up, and it works again for 6 months or so.
Rproject is offline
Brake Lights not working...all other lights work Dashash TJ Wrangler Technical Forum 15 12-28-2016 01:20 PM
Brake lights not working. AnonymousD YJ Wrangler Technical Forum 2 09-07-2010 09:57 PM
Brake Lights not working sxysouthtx TJ Wrangler Technical Forum 6 07-09-2010 10:07 PM
Brake lights not working but running lights fine snaustin09 YJ Wrangler Technical Forum 4 11-24-2008 12:22 PM
Brake Lights Not Working billybitter TJ Wrangler Technical Forum 6 11-28-2006 08:45 AM
