So just a little background. Bought the jeep about 3 years ago, it was in pretty good shape. I just did enough to keep it running at the time. Added a soft top a 4" RE lift and put hurcaliner on the floor. I drove it for about a year as a daily driver and now have a truck so its time to restore it. Last July it wouldnt pass smog. Pulled the head and found burnt valves, bad valve guides and seals, and a blown head gasket. I pulled the engine to rebuild it and one thing led to another and next i knew, i was taking the body off . I almost have it back together completely so i figured it was time to start a thread. Enjoy.
I cant find my pics from when i first got it. ill try to add them in the next couple days if i can.
sorry for some of the crappy pictures, i dont have anything except my phone in the shop with me.:brickwall
the distruction begins. the inside was a mess. the PO really screwed up the wiring.
the battery had leaked acid everywhere causing rust throughout the engine compartment and frame
the frame after being stripped down prepped and painted.
I did all the body worked myself and was fairly surprised how the paint turned out. Both back corners were crushed, the front end had been pounded to death with gravel and the passenger door had got personal with a tree. I used PPG single stage paint with a filler/base coat
The freshly painted body arrives from getting a fresh coat of paint inside and out
the assembly begins
i repainted all of the trim parts
more progress
removing the body. decent pic of what it looked like before.
rear almost finished
while waiting for parts and money i began building a front and back bumper, tire carrier, and some sliders.
front bumper fairly done
beginning of sliders
slider body mount tie-ins
completed sliders
start of rear bumper. crazy to cut those angles
mounting plate. this bolts right where the bumperettes mount
mount welded
Finally got some time and parts in. including an A/C kit from jeepair.com
i know i know you saying, A/C in a jeep!?!?! i hear ya it wasnt my personal choice. someone else will be also driving this jeep and they said they couldnt drive it without air, and they paid for it, sooo i went with it. ill still drive it with no top and no doors tho. :2thumbsup:
all new electrical. no more of the previous junk
the trusty(sometimes) chilton's manual on hand.
engine is running at this point. most of engine compartment is done.
put grille radiator and condenser in
progress so far on the inside.
dont worry ill be redoing the floorpan. the paint got a little messy
dash being installed. the dash used to be the OEM bluish greenish color in the sahara's but i fixed that with some SEM flexible coating. everything is now black. the SEM paint is pretty amazing stuff. i also threw in some new speakers and a marine radio.
forgot to add this pic earlier. these are the mounting tabs for the front bumper.
lol ya thats right. the PO didnt share that view point. i pulled about 200 feet of wire out form under the dash that had all been cut the wires twisted together and then used masking tape to put them together.:nono:
you know ive been tossing the idea around about starting to build stuff to sell and just havent done it yet. this summer when school is out i might fab up a bunch of bumpers and sell them.
What would you all be willing to pay for one of these bumpers? front or rear
I wasnt able to get much done this weekend. I found this blown out heim joint on my truck this weekend which is my DD so it took most of my time. However, i was able to get rid of the ugly color on the wheels and put in a new windshield. I also threw a seat in and took it around the block for the very first time. It did good. No major problems, i just dont have any brakes yet. A little bleeding should fix that.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
