92 YJ 4" lift / tires? - JeepForum.com
post #1 of 4 Old 09-17-2001, 10:54 PM Thread Starter
TFD
I have a 4" lift on my 92 4.0 YJ with a Hardtop and automatic. I need practical advice on tires on 15X8 Rockcrawlers. I still have the Dana 35 rear and am pretty sure 32" tires will grenade my factory rear if I offroad it hard. I am leaning towards 31X10.5, what's the best All-terrain or Mud that can survive daily pavement driving? Thanks in advance.
92 4.0 Auto, Hardtop, BFG Muds, 4"lift, Swaybar Discos, No trackbars, K&N, Hi-Lift, Work in Progress
TFD is offline
post #2 of 4 Old 09-17-2001, 11:10 PM
bigblueyj
just go with 33's and be fine and for street muds get bfg muds my friend got 35,000 out of his
bigblueyj is offline
post #3 of 4 Old 09-18-2001, 06:45 AM
RodeoRob
RodeoRob's Avatar
I think you're being a little cautious. IMHO, you can run 33 x 12.50 with a light foot and still hit some of the hard trails out there. Of course if you like to go flying through things at wide open throttle, then... might wanna reconsider, but smart driving you should be fine. Especially if you aren't locked and have the stock gearing. There are *some* that even run 35's on locked D35c without breaking them.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
post #4 of 4 Old 09-18-2001, 06:33 PM
osburn
osburn's Avatar
Just dump the steel wheels! They add so much weight to the setup. With an alloy you'll get better pickup, better braking and better gas mileage. Not to mention the fact that you won't be stressing the shafts as much. You can increase tire size significantly using alloys before you get near the weight of a smaller tire on steel. That, and the benefits of steel are hogwash from my experience. Sure, you can pound them back if you bend them. But they'll need to be replaced in any case cause they're most likely gonna leak at least slowly. On top of that, they bend way too easily. With stock axles, you're just better off with a lightweight rim.
Matt Osburn
Score 1032
osburn is offline
OME 2" lift and 1.25" body lift. Gives good ride - adequate clearance for 33" tires? CB3 TJ Wrangler Technical Forum 30 11-25-2009 12:13 AM
Another wheel and tire size question? (Will 32" tires fit with 2" lift) TJ's02TJ TJ Wrangler Technical Forum 12 10-30-2009 08:43 PM
Steering seems loose and wobbles in bumpy turns after 4" Lift and 33" M/T Tires/Wheel cpd3020 TJ Wrangler Technical Forum 8 10-28-2009 01:18 AM
tires (32" tires with 2" lift and 3 speed auto w/ 3.07 gears) libertynewyork TJ Wrangler Technical Forum 15 10-20-2009 10:03 AM
1989 YJ 4.2 AUTO,WEBBER CARB,6" lift,33" tires,besttop supertop, yjmikea YJ Wrangler Technical Forum 4 12-14-2008 09:59 AM
