92 yj 2.5 ax5 lost 5th gear clutter noise plz help - JeepForum.com
post #1 of 18 Old 03-08-2010, 08:56 PM Thread Starter
92yjpittman
i have 92 yj 2.5 ax-5 trany bone stock with 121k just bought it last week. I was driving bout 60mph in 5th hit brakes hard then when i hit the gas 5th was lost. makes ticking noise from tranny when idle. all other gears still work fine. any help will be greatly appreciated. Thanks
92yjpittman is offline
post #2 of 18 Old 03-08-2010, 10:36 PM
Opihi59
from here it gets rough
Opihi59's Avatar
http://www.jeepforum.com/forum/f12/a...emoval-908252/
Above link may be helpful, likely you lost the c clip, it happens to AX 5's.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #3 of 18 Old 03-08-2010, 11:08 PM Thread Starter
92yjpittman
I was Thinking that i researched it more is the ticking sound that broken clip bouncing around
post #4 of 18 Old 03-09-2010, 12:27 AM
Opihi59
Opihi59's Avatar
Nope. Broken clip is in the bottom of the rear case now. Ticking would be the loose gear backed off its splines and bouncing about loose on the rear part of the shaft.
Opihi59 is offline
post #5 of 18 Old 03-09-2010, 10:33 AM Thread Starter
92yjpittman
Where can i get the snap ring with the collar
post #6 of 18 Old 03-09-2010, 12:07 PM
Opihi59
Opihi59's Avatar
Try post number 9 in the link I provided above.
Opihi59 is offline
post #7 of 18 Old 03-09-2010, 02:31 PM Thread Starter
92yjpittman
i went to tranny shop in our small town he rebuilt my 700r4 couple months ago. he called his parts man and he said i needed to replace the bearing in 5th. said the bearing is causing to ring to break is that true
post #8 of 18 Old 03-09-2010, 02:37 PM
Opihi59
Opihi59's Avatar
This has not been substantiated by numerous other experienced Forum members who have experienced this problem.
Opihi59 is offline
post #9 of 18 Old 03-09-2010, 09:33 PM
baltimorebiker
I just completed the repair on this exact same problem . very easy repair I used the new clip and retainer collar from the post stated and it works PERFECT . had gotten a price of 500-700 dollars to rebuild the tranny and fix it . I tried this sure enough 5th gear had slipped back and i found the clip in the bottom . the repair was rather simple and was under say 80 bucks including all the fluids and parts . if you have any questions shoot me an email I will be glad to help in any way i can .
chuck
baltimorebiker is offline
post #10 of 18 Old 03-09-2010, 10:14 PM
YJake
That tranny in the thread is mine. The fix was very easy to do for even me (Although I did have Max guiding me). Just make sure you don't lose any of the bolts and you're golden
Jake
/l , [____],
l---L--[]lllllll[]-_
()_) ()_)==@=)_)
Originally Posted by clemsonfan16 View Post
The 4banger only whines because it wants more!
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJake is offline
post #11 of 18 Old 03-10-2010, 02:15 PM Thread Starter
92yjpittman
yjake did yous rattle a lil bit when ur in nuetral when your snap ring broke
post #12 of 18 Old 03-10-2010, 02:43 PM
YJake
Yes! Mine made all kinds of terrible rattling noises when it was idling in neutral. however, my main and counter 5th gears were destroyed and their teeth were sitting in the botom of the tranny.
I hope that this is not the case with you.
Jake
/l , [____],
()_) ()_)==@=)_)
YJake is offline
post #13 of 18 Old 03-10-2010, 06:29 PM Thread Starter
92yjpittman
how much did that 5th gear and counter cost you
post #14 of 18 Old 03-10-2010, 06:38 PM
Bryan01702
does it make a ticking rattling noise while driving to. sounds like the symptoms im having but i havne't lost any gears. It pops out of 2nd once in awhile but thats the extent
Bryan01702 is offline
post #15 of 18 Old 03-10-2010, 07:18 PM Thread Starter
92yjpittman
yeah it does sometimes while driving but mostly after you ran it a while then when you stop and its idlin its more staedy
I lost 5th gear in my AX-5 wolf3902 YJ Wrangler Technical Forum 19 08-11-2011 07:11 AM
Whirrring noise in 5th...lost all but 4th gear? boatingncst8fan YJ Wrangler Technical Forum 11 05-17-2009 10:04 PM
Lost my vibes, but I also lost 2nd gear?? pookie TJ Wrangler Technical Forum 14 01-23-2006 10:34 PM
I have lost fifth gear renegadeyj YJ Wrangler Technical Forum 4 11-29-2005 07:41 AM
Clutter...or too tacky? Poseidon17 TJ Wrangler Technical Forum 10 07-29-2002 10:26 AM
