92 wrangler washer pump plastic nuts where to buy? - JeepForum.com
post #1 of 2 Old 09-06-2011, 06:10 PM Thread Starter
02grandy
02grandy's Avatar
The projects continue the wiper reservoir bottle was removed and both motors are just sitting there. it looks like they are missing rubber washers if not then at least the plastic nuts that screw on to hold them on the tank . where can i buy that or am i screwed and need to buy new motors which will come with them? thanks
02grandy is offline
post #2 of 2 Old 09-06-2011, 06:46 PM
tdewit
I think you are screwed, unless youcan find some nut at your local hardware store that fits. If not, you have 2 options:
http://www.quadratec.com/products/55310_0103.htm or
http://www.quadratec.com/products/55310_01.htm
tdewit is offline
Washer Fluid Pump faaantastic YJ Wrangler Technical Forum 6 06-28-2010 07:03 AM
stripped plastic cowl nuts caused leak MarkOlson TJ Wrangler Technical Forum 6 06-10-2010 03:58 PM
'92 YJ Washer Pump Front jeepsaab YJ Wrangler Technical Forum 0 01-14-2010 09:46 AM
Winsheild washer pump Slenny JK Wrangler Technical Forum 4 07-14-2009 04:00 PM
washer pump replacement CostaRicaJeep YJ Wrangler Technical Forum 6 02-16-2007 08:34 PM
