92 Wrangler computer codes 12 33 and 55 - JeepForum.com
post #1 of 6 Old 09-10-2009, 09:26 AM Thread Starter
Bowfin
My CEL light is showing on my Jeep, turned out to be a bad thermostat as the code indicated the motor wasn't heating up fast enough and running too cool. I installed a new TStat and disconnected the battery to reset and my CEL is still lit. Now I get codes 12 33 and 55.
12- battery has been disconnected
33- no AC relay
55- end of codes
To me this indicates all the codes are clear as my Jeep didn't have AC and the only way to reset the Codes is disconnecting the battery. It's also my understadning that all non-ac jeeps will show a code 33 when retrieved, but shouldn't cause a CEL light.
So why would I still have a lit CEL light with those 2 codes- 12 and 33?
'92 Black YJ 4.0, 5spd, hard-top
My favorite color on my Jeep is mud ;D
Bowfin is offline
post #2 of 6 Old 09-10-2009, 09:36 AM
93jeepyj
you shouldnt. How long did you disconect the battery for ? sometimes you need to leave it disconected for a half hour or so to let all the power drain out of the capacitors in the computer.
93jeepyj is offline
post #3 of 6 Old 09-10-2009, 11:01 AM
Louie4
"You pass butter"
Louie4's Avatar
I agree. I would just take the terminal off for the night and put it back on in the morning. Waiting that long isn't necessary but it only takes a couple of minutes to put it back on.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #4 of 6 Old 09-10-2009, 11:03 AM
cjapgar
cjapgar's Avatar
with the yj the codes an come through the dash check engine light 12= start of sequence 33= air conditioner 55= end of sequence
so you are good
_______
/l ,[____],
l---L []lllllll[]-
()_)-()_)--o-)_)
Bacon is meat candy!
ΜΟΛΩΝ ΛΑΒΕ!
cjapgar is offline
post #5 of 6 Old 09-10-2009, 01:09 PM
92yjwrangler
the battery just mean in the last like 50 key cycles the battery was disconnected
92 wrangler yj 33in Dunlop Mud Tires
pioneer head unit and front speakers sony amp with 2 rear 6x9 alpine pro series speakers
92yjwrangler is offline
post #6 of 6 Old 09-10-2009, 05:43 PM
idaholtby
The CEL should be lit with the ignition key on, but extinguish when the engine is running. 12,33,and 55 will not trigger the CEL to light while the engine is running.
idaholtby is offline
FAQ - Check Engine Light and Diagnostic Trouble Codes (Error Codes, Problem Codes) Wheelin98TJ TJ Wrangler Technical Forum 6 05-15-2009 06:05 PM
'93 Wrangler Codes Kman1983 YJ Wrangler Technical Forum 8 10-13-2008 06:18 PM
Location of Computer 88 Wrangler 4.2L? Jim93YJ YJ Wrangler Technical Forum 26 03-06-2007 11:52 PM
Computer Codes on 97 CJeepFreak84 TJ Wrangler Technical Forum 3 11-01-2004 12:21 PM
Wrangler problem ... new computer? JeepinJosh TJ Wrangler Technical Forum 3 12-05-2003 08:14 PM
