92 wrangler 4.0 crankshaft Position sensor check - JeepForum.com
post #1 of 2 Old 01-20-2012, 09:25 AM Thread Starter
ernaldamerican
Is there a check (resistance ) that you can do with a CPS removed? haynes says when engine is warmerd up across pins A&B you should get 125-275 ohms reisitnace, but my motor won't start. I'm trying to see if the CPS I got from Advance auto is bad.
Second if I have the new one installed is there a check you can do without motor running?
Thanks for all the help
ernaldamerican is offline
post #2 of 2 Old 01-20-2012, 09:31 AM
pasinbuy
One CPS check that I read in the book was to disconnect the CPS at the plug for one minute. Then plug it back in. If the rig then starts the CPS is bad.
pasinbuy is offline
Crankshaft Position Sensor or Camshaft Position Sensor? TennesseeTJ TJ Wrangler Technical Forum 19 11-28-2015 06:27 PM
Crankshaft Position Sensor for 6sp sheldon529 TJ Wrangler Technical Forum 3 10-14-2011 06:51 PM
Crankshaft Position Sensor??? Crawler92 YJ Wrangler Technical Forum 3 02-13-2011 05:31 PM
Check engine light due to camshaft/crankshaft position sensor caseyLA TJ Wrangler Technical Forum 7 07-26-2010 08:53 PM
Crankshaft Position Sensor lexington TJ Wrangler Technical Forum 0 12-02-2002 12:53 PM
