92 Renegade 4.0 engine,tranny and tcase - JeepForum.com
post #1 of 15 Old 03-12-2014, 01:50 PM Thread Starter
pheaz
92 renegade 4.0 motor/tranny swap?
I have a chance to get a low milage 4.0,auto tranny, transfer case, all intacted, out of a 94 Grand Cherokee. From what I have researched, my 92 Renegade 4.0 has a 32RE trans.(3 speed) and the 94 Grand has a 42RE (4 speed),.Not sure of transfer case number yet. What problems if any will I have with a complete change out? (motor,transmission,transfer case).
pheaz is offline
post #2 of 15 Old 03-12-2014, 01:57 PM
Jeepsr4me
driveshaft length since the 42 is longer
Jeepsr4me is offline
post #3 of 15 Old 03-12-2014, 03:18 PM
XJ93
Are you sure you have the RE and not the RH?
XJ93 is offline
post #4 of 15 Old 03-12-2014, 07:52 PM Thread Starter
pheaz
Petty sure it's the RE. I worry about the 42 being longer. As for engine wise pretty well the same I guess. Original engine blown and tranny was slipping abit. If the transfer is different will my old one bolt up to the 42 trans?
pheaz is offline
post #5 of 15 Old 03-12-2014, 08:59 PM
Jeepsr4me
yes your old transfer case will bolt right up
post #6 of 15 Old 03-12-2014, 10:01 PM Thread Starter
pheaz
Dumb question here but what issues may I run into? (Linkages, sensors, etc etc) how long should this Jeep operation take?
pheaz is offline
post #7 of 15 Old 03-13-2014, 02:04 AM
carnuck
1984 J-Series Truck
Check the length of the stickout on the trans. 42RE may have 15/16" longer output. PartsMike sells a 1" clocking ring to fit.
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
post #8 of 15 Old 03-13-2014, 04:35 AM
superj
the grand cherokee transmission is known for needing the have the bands adjusted regularly too or it takes a while to go in gear when you shift to reverse. the grand cherokee tcase is full time 4x4 also. but, like mentioned above, your 231 tcase might bolt up and if it doesn;t, its not hard to open the tcases and swap the part that doesn;t fit.
i had a 93 grand cherokee and swapped to wrangler 231 tcase once upon a time. my grand cherokee had 2xxk miles on it when some chick fell asleep with cruise control on and totalled it out from under the wife and i at a stop light. great truck
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #9 of 15 Old 03-13-2014, 09:03 AM Thread Starter
pheaz
As always, THANK YOU for the good info.
pheaz is offline
post #10 of 15 Old 03-13-2014, 12:06 PM
XJ93
Isn't the RE electronic controlled vs the RH being hydraulic though? P.O. would then have to do some wiring as well would he not?
XJ93 is offline
post #11 of 15 Old 03-13-2014, 09:28 PM Thread Starter
pheaz
Great thought XJ93. I hope they're both RE, but will have a better understanding Monday morning.
pheaz is offline
post #12 of 15 Old 03-15-2014, 10:49 PM Thread Starter
pheaz
So the old is a RH and the Cherokee has a RE. So what am I up against?
pheaz is offline
post #13 of 15 Old 03-15-2014, 11:01 PM Thread Starter
pheaz
92 Renegade 4.0
I drove this 92 Renegade with a weak engine at take off tonight. I'm wondering if the motor is actually the issue. Fires right up runs good and revs smooth and quick. After driving a few miles if you come to a complete stop, on take off it spits and sputters but will eventually pick up. I tried in drive or reverse seemed to be same results. The tranny does slip abit when cold, but when spitting and sputtering the rpm pretty well hold at 1100 until she decides to go. What's your thoughts? Fuel filter changed and new plugs installed.
pheaz is offline
post #14 of 15 Old 03-18-2014, 12:38 PM
XJ93
Air filter, cap, rotor, good spark at the coil? Unplug the o2 sensor and see if you get the same results at operating temp.
XJ93 is offline
post #15 of 15 Old 03-18-2014, 02:36 PM
The_Goob
Hell on Wheels
The_Goob's Avatar
do you smell sulfur? clogged cat will put off that smell and really bog you down. I found that out when I had a plug wire go bad and the fuel was going unburnt.
YJoTM ~April '14 ~June '15 ~April '17
The_Goob is offline
