92 Qtec Cowl Rubber HELP - JeepForum.com
post #1 of 15 Old 08-06-2015, 08:31 PM Thread Starter
madoats
I have read every thread I can find on the matter and I'm stuck. I do as much of my own repair as I can, and this is by far the hardest task I've taken on to date. I bought the Qtec cowl rubber without looking at the forum first
I installed it no problem, looks great.....but my windshield is 3 inches away from my roll cage (I think you call em spreader bars). I read someone used ratchet straps to get them closer together, someone else loosened some bolts by the hinges but I have no clue which ones! Anyone have experience with this?!?!
Thanks in advance!
--madoats--
92 YJ
madoats is offline
post #2 of 15 Old 08-06-2015, 11:03 PM
Drednot
Let it sit out in the sun with the windshield down till that seal gets hot and softens up then put the windshield up and it should squish and let it come back further.
If you need to use the ratchet strap, be careful you don't bend the windshield and crack the glass.
If it still wont go, leave the spreader bars off and you can run with your windshield down easily without having to disassemble it every time.
91 YJ Sahara, 4.0L, AX-15/NP231, D30/D35@3.07
12 Cherokee 4x4,3.7L,42RLE/MP1522, D30M/8.25@3.73
Emission test=YES
"Non Vi Sed, Arte"
Drednot is offline
post #3 of 15 Old 08-07-2015, 07:41 AM
Mike Romain
I would use the sun and/or a hair dryer on it first to soften it up, then try compressing it. The bolts that are used to adjust the rake of the windshield are the three bolts from the top part of the hinge, But, if you use those before compressing the gasket, that will just raise the frame up which can be an issue for fitting a hardtop on.
Mike
Mike Romain is offline
post #4 of 15 Old 08-07-2015, 07:48 AM
jeep63
YJ Collector
jeep63's Avatar
I used a ratchet strap on the two I did and it worked fine. I did not bend the windshield frame or crack the windshield. Just go slow, let it sit and then move it again, repeat until you are close enough to begin the bolts. Continue the process until you get everything tight. Just take it slow and give the seal time to compress. Heating it up will definitely help speed up the process.
jeep63 is offline
post #5 of 15 Old 08-08-2015, 02:22 PM
Rwrangler
were did you attach the ratchet strap?
Rwrangler is offline
post #6 of 15 Old 08-08-2015, 02:38 PM Thread Starter
madoats
Someone attached to the little metal u bar thing at the top center of the windshield frame. The PO removed mine for huge aftermarket speakers so, I do not know if that will work.
Thank you for the advice everyone! She's sitting out in the sun. Fingers crossed. Need to get this project done ASAP.
--madoats--
92 YJ
madoats is offline
post #7 of 15 Old 08-09-2015, 01:59 AM
Rwrangler
I have the same problem. I installed a new windshield cowl rubber about 2 years ago and it still won't let the windshield come all the way back. I call Morris 4x4 (were I purchase it) they said all after market rubber is harder than OEM. I had to take 3" longer bolts to start pulling it in, then 2", then 1", then OEM. It left a gap between the front corners of my hard top and doors, every slight but it's there.
post #8 of 15 Old 08-09-2015, 03:11 PM
jeep63
YJ Collector
jeep63's Avatar
I used the middle footman loop.
jeep63 is offline
post #9 of 15 Old 08-10-2015, 10:24 AM Thread Starter
madoats
I had no problems once I left it out in the sun. It was 101 here so maybe that helped. I left the windshield down with the cowl rubber attached for a couple hours. Then at about 3 pm, I put the ratchet strap lengthwise across the windshield and back behind the roll bars behind the seats. I dont have a frontman loop so I had to watch it to make sure it didn't slip off the windshield frame. I just went slow and steady. It came all the way together and I put all the bolts in. I have had to tighten them since then.
madoats is offline
post #10 of 15 Old 08-10-2015, 11:31 AM
Rwrangler
Can the roll bar move if you use it to winch the windshield?
post #11 of 15 Old 08-10-2015, 01:41 PM
DirtKar
I pledge allegiance.
DirtKar's Avatar
What do you mean?
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
post #12 of 15 Old 08-11-2015, 10:13 AM
Rwrangler
When your winching the windshield with the roll bar, can the roll bar move? Is it welded or bolted down? The reason I ask this question. If you pull the windshield all the way to the roll bar mount and the roll bar doesn't move, why is there a gap at the top of the doors/hardtop? It seems to me that the windshield would be back in it's original position (as new), even if the cowl rubber is to hard, the top of the windshield would be in it's original position?
post #13 of 15 Old 08-11-2015, 01:33 PM
Mike Romain
Yes, the roll bar ends up there move. They have a set screw on them for adjusting the windshield rake when switching tops and doors around.
Mike
post #14 of 15 Old 08-12-2015, 03:24 PM
Rwrangler
Mike Romain,
Thanks for that info. I didn't know that. It was very hard for me to pull the windshield up to the roll bar. The rubber was way to hard, still hard. I had to use long bolts, shorter bolts then shorter bolts then OEM. I was really afraid of breaking my windshield. But I hate the fact I have a small gap between the hard top and the top front corner of my doors. My jeep has always been tight as a drum. It seems like everything I buy aftermarket doesn't quite fit.
post #15 of 15 Old 08-13-2015, 05:49 PM
DirtKar
DirtKar's Avatar
Mike Romain,
If you didn't move the spreader bars ( the bars over your doors) then your hardtop should still fit correctly as before the new seal. Do you have any pics?
YJOTM JULY 2014
DirtKar is offline
