92 Jeep YJ No Spark at Plugs - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 92 Jeep YJ No Spark at Plugs
Thanksgiving/Black Friday/Cyber Monday Deals at JeepinOutfECGS Black Friday Sale!!Gear Installs at CCOR Special
Unread 11-20-2014, 02:25 PM   #1
johnnyj4811
Whats going on jeepforum, I have a 92 Jeep YJ 4.0 manual that I cant seem to get started.
I have two issues...
First I am getting no spark to the spark plugs to ignite the cylinders, however I am getting spark out of the coil. So far I have replaced my cap and rotor, plugs and wires, coil, crank sensor, battery, alternator and ECU. Still no spark to the spark plugs.
Second My also brand new fuel pump will not engage due to the fact only 6-8volts are coming from the connector and the fuel pump requires 12volts to run.
Please help, I have been trying to get her running for weeks.
johnnyj4811 is online now   Reply With Quote Quick reply to this message
Unread 11-20-2014, 03:03 PM   #2
mike134
Sounds frustrating, better stop throwing parts at it, or its going to get expensive!
First, does your check engine light come on when you turn the key to the ON position? This is a very important symptom for 91-95 model years.
Any check engine codes?
mike134 is online now   Reply With Quote Quick reply to this message
Unread 11-21-2014, 12:37 PM   #3
johnnyj4811
Yes very frustrating, I guess it comes with the territory lol. But when the key is in the on position only the seat belt light comes on for all of two seconds then goes away.
Unread 11-21-2014, 01:31 PM   #4
mike134
ok, in a 92, no check engine light when the key is turned to ON means that the capacitors in your engine computer are bad. I see that you swapped the ECU already. was that NOS or was it from a junkyard?
You need to follow this thread: http://www.jeepforum.com/forum/f12/c...rs-ecu-492597/
The electrolytic material inside the capacitors dries out after 20 years or so and they need to be replaced. It costs about 50 cents if you know how to solder. If you don't know how to solder, bring it to a friend or learn this very useful skill.
If you have an old stereo, television, computer monitor, ham radio, They can often be repaired in the same way. One of the very first things to try is replacing all of the old electrolytic capacitors.
Unread 11-21-2014, 03:14 PM   #5
johnnyj4811
I bought the computer online from rock auto, its refurbished. My old computer wouldn't even produce spark to at the coil. Is there a chance this new computer could be defective still?
Unread 11-21-2014, 03:35 PM   #6
mike134
its possible the caps are bad. The hotter the capacitor the shorter its service life. So running the computer and the engine makes the electrolytic material expire faster. However, it will go bad eventually without being used anyway.
It follows a curve like the one at the bottom of this post, where heavy use brings failure towards "Practical Life Expectancy". However, we are unfortunately going past "average life expectancy" now. If your caps made it past the hump, expect failure soon..
You may want to ensure that your check engine light bulb isn't burned out though. Its rare, but a possibility.
Unread 11-21-2014, 03:52 PM   #7
johnnyj4811
I could solder new capacitors in but I will return my new ECU if thats the case because I still have my core. I will check the lightbulb tomorrow just to make sure...also I was reading that no spark at the plugs could be the cam sensor or the distributor assembly, could this be a possibility also? I really don't want to keep throwing money at this thing I just want to go wheeling.
Unread 11-21-2014, 04:00 PM   #8
mike134
Yeah, get the money back for the ECU you just bought. Solder the capacitors into the old one. These computers are pretty rugged and almost always repairable. The three capacitors will cost about 50 cents.
the cam sensor can cause this problem if your vehicle has one.
Before doing more sensors, I would reinstall the old computer and see if the no CEL symptom still occurs. If no CEL, change the caps.
You could have a problem in addition to the capacitor issue. To find out, you can charge the computer up and try to start the vehicle before doing your cap swap. Grab your favorite magazine and turn the ignition to ON. Wait 15 minutes (use magazine here). If the computer fires up in 15 minutes you will hear a relay kick on and the CEL should come on to indicate the computer is ready. You can then turn the vehicle on.
Unread 11-21-2014, 06:56 PM   #9
johnnyj4811
Ok, I really appreciate the help btw! This is my first thread on JEEPForum and so far its been awesome! Tomorrow, Im gonna start on the things we discussed and ill check back in.
Unread 11-21-2014, 08:25 PM   #10
laybackman
Bikini Bridge Inspector
laybackman's Avatar
Turn your ignition switch to the ON position and wait......until the CEL lights up. If it does the engine will then fire and run. You have bad caps in the ECM.
Chicks dig me.....Fish fear me
Getting older, I have developed some special skills. I have the ability to cough, sneeze, fart and pee at the same time.
"If we cannot afford to take care of Veterans, then we should stop making them."
David C. Wilker Jr. USAF (RET)
laybackman is offline   Reply With Quote Quick reply to this message
Unread 11-22-2014, 12:25 PM   #11
johnnyj4811
Ok, to not overlook any possibilities, I checked the light bulb of the check engine light and it is fine. I even switched my seatbelt lightbulb with the check engine lightbulb to make sure. I also checked all fuses and they all look fine. Listening to Mike I set the key to the on position and let it sit for 15-20 minutes. After this, I checked for any codes and the check engine light still did not illuminate. My friend has a YJ as well I am going to start by switching his computer into mine and see if it makes a difference.
My question now is, could it be possible that anything else besides a bad ECU/ECM would cause no check engine light illumination. Or could it be possible that everything is good but maybe there is a loose or broken wire somewhere else or maybe corrosion I cant see inside the fuse box? I've searched for any wires in poor condition but they all look in good shape.
Unread 11-22-2014, 02:47 PM   #12
mike134
There could be a problem in addition to the bad capacitors, but you have the classic bad cap symptoms so at the very least that needs to be addressed.
You could try waiting longer than 15 minutes since it is cold out. 15 usually does it though. The CEL has to come on before the engine will start.
Unread 11-22-2014, 03:47 PM   #13
laybackman
laybackman's Avatar
Check EVERY fuse in your PDC under the hood and under the dash board. I mean pull each one and test it for continuity with a multimeter
Unread 11-22-2014, 04:24 PM   #14
Mark05059
especially the dome fuse
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline   Reply With Quote Quick reply to this message
