91 yj trouble in 4x4 - JeepForum.com
post #1 of 15 Old 01-05-2013, 02:48 PM Thread Starter
celticrebel
I would appreciate all help i could get. I have a 91 yj 4.0 open dif with stock hp dana 30 front dana 35 rear. When i shift into 4x4 the jeep runs fine till it seems like anything tougher then flat dirt road then it binds up and will not move. The rear tires will spin but not the front. I was told it could be the cad so i did a diy posi lock and it works fine. I have checked the gear ratio and they are the same front and back. I have put the jeep up on 4 jacks in the garage and tried to re create the problem as well as make sure the 4x4 works it does. I can not get it to recreate in garage only out on trail. I have also pulled the cover on the front dif and everything appears fine no chipped gears that i could see. I apologize for the long post just wanted to get all the info out i could.
celticrebel is offline
post #2 of 15 Old 01-05-2013, 02:55 PM
Red93yj
2011 JK Wrangler
Does it lock up while turning or going straight.
Red93yj is offline
post #3 of 15 Old 01-05-2013, 02:59 PM
Ripper3494
sounds like a transfer case issue to me... i know you cant create it in the garage but does your front driveshaft spin or no while the front wheels are stuck and the rears are spinning? maybe have a friend watch. or go in the front yard, hold your brakes in 4wd and give it some gas
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #4 of 15 Old 01-05-2013, 03:26 PM Thread Starter
celticrebel
It locked up once going straight and once turned slightly
post #5 of 15 Old 01-05-2013, 03:31 PM Thread Starter
celticrebel
I dont think the driveshaft was spinning not sure though. Mabe i should just go out to the desert with all my tools wait for it to happen then start tacking everything apart.lol
post #6 of 15 Old 01-05-2013, 03:35 PM
Ripper3494
If the shaft doesn't spin that's deff a problem inside your t case
build thread:
RC vs BDS
post #7 of 15 Old 01-05-2013, 07:45 PM Thread Starter
celticrebel
Drive shaft does spin just not sure if it does when jeep bound up
post #8 of 15 Old 01-05-2013, 08:00 PM
mike_breaker_5
axle u-joints?
driveshaft u-joints?
carrier bearings tight when you checked the diff?
if not those i would also say it may be an x-case issue.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #9 of 15 Old 01-07-2013, 07:49 PM Thread Starter
celticrebel
Originally Posted by mike_breaker_5 View Post
axle u-joints?
What is the best way to check u-joints and carrier bearings. They appear fine but would like info on proper way to check.
post #10 of 15 Old 01-08-2013, 02:45 AM
mike_breaker_5
u- joints can be tricky, at least the ones in the knuckles. any other u-joint you can normally feel or hear. for the joints in the knuckles, the wayy i do it, jack one front tire up leaving it free to turn with the steering. rotate the tire with short quick jerks and listen for clunking, grinding, or grating. reach your hand in there and grab one side of the axle shaft. wiggle that little sucker around in there and feel for the same as before. you can also rotate it slightly to feel for play, but be careful it's easy to get pinched. lastly if none of those yield a result give her a good old visual inspection to look for cracks of evident wear. i suppose you can do the visual inspection first, but whatever you get the point.
i suppose the carrier bearings would just be a visual inspection mostly. i suppose you could jack the front up, spin the tires, and listen for noise. they usually aren't a failure point. i only mentioned it because you said you had it apart.
another thing i just thought of...
is your front pinion nut torqued properly and is the seal in good shape? if these are not in proper then you could get a similar issue i would bet.
post #11 of 15 Old 01-08-2013, 07:12 AM Thread Starter
celticrebel
Ok thanks i will check on my first day off. I will give a update
post #12 of 15 Old 01-08-2013, 01:18 PM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
I'd be looking at the t-case first. I've never heard of a 231 locking up. Lucky for you they are stupid simple to remove and crack.
Poke is offline
post #13 of 15 Old 02-11-2013, 06:03 PM Thread Starter
celticrebel
Update took apart t case for sye install and every thing looked good. I am removing skid plate spacer since i am getting a new rear drive shaft and replacing both axles ford 8.8 rear dana 30 front both with 4.10 gears. Hopefully problem will be fixed.
post #14 of 15 Old 02-15-2013, 11:12 AM Thread Starter
celticrebel
I ordered the 8.8 axle swap kit from ruffstuff 2 weeks ago still not here not very happy.
post #15 of 15 Old 02-15-2013, 12:45 PM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
3 words.... KOH. Ruff Stuff is the best vendor one can find. KOH was last week and Dan was there with his team fixing other peoples broken cars for free. Give him some time to catch up.
KOH = King of the Hammers
edit - thats 4 words
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
