91 YJ stroker overfueling - JeepForum.com
post #1 of 14 Old 07-19-2014, 09:06 PM Thread Starter
JimG91YJ
I recently installed a 4.7L stroker (4.0L block) in my 91 wrangler. It runs very rough at low rpms with little power and backfires through the intake. I have replaced the temp censors in the intake and thermostat housing, also replaced IAC, TPS, Map censor, and fuel pressure regulator. Nothing seems to help. Any suggestions?
JimG91YJ is offline
post #2 of 14 Old 07-20-2014, 04:18 AM
Mike Romain
Miss a tooth on the timing chain? Did you do the double check count of the 15 pins between the dots on the gears?
Low vacuum and low compression are usually the result of that, so a quick test of those might help narrow it down some.
Mike
Mike Romain is offline
post #3 of 14 Old 07-20-2014, 04:45 AM Thread Starter
JimG91YJ
Timing set was installed by the manufacturer (ATK performance Engines), but thanks I will check. A friend sugested advancing the cam timing by one tooth.
JimG91YJ is offline
post #4 of 14 Old 07-20-2014, 07:13 AM
JMickey
Moving your timing chain by a whole tooth sounds like way too much to me. I wouldn't do it. When engine builders advance or retard cam timing it's only a few degrees. One tooth is more than a few degrees. Have you checked your ignition timing? Have you checked your crank sensor? What about your O2 sensor? Where is your Fuel pressure at?
JMickey is offline
post #5 of 14 Old 07-20-2014, 11:36 AM Thread Starter
JimG91YJ
ignition timing is correct, fuel pressure is correct, all sensors have been replaced. Cam timing was correct (15 pins between the marks), I moved it 1 tooth and it seemed to help. It runs much better, but still not right. I will call the engine builder Monday.
JimG91YJ is offline
post #6 of 14 Old 07-20-2014, 05:13 PM Thread Starter
JimG91YJ
apparently moving the cam timing is not a good idea, it seems to run better at an idle but has no power when under a load. I changed it back to where it should be. I'm thinking that a larger throttle body might help?
JimG91YJ is offline
post #7 of 14 Old 07-21-2014, 04:24 AM
Mike Romain
If it were mine, I would be talking to the engine builder about it. Backfiring out the intake isn't a good thing.
Mike
post #8 of 14 Old 07-21-2014, 01:23 PM Thread Starter
JimG91YJ
I tried, still waiting for them to call me back. I've called them several times. I won't recomend buying anything from them (ATK high performance engines). It was purchased through Summit Racing, the website says it will work in a '91 wrangler, but when I talked to them today they say it needs the computer re-programed, About $600 from Jet performance chips.
JimG91YJ is offline
post #9 of 14 Old 07-21-2014, 05:43 PM Thread Starter
JimG91YJ
I finally found someone that knows what they are talking about, Zack Steele, owner of 505performance, instructed me over the phone on exactly what I needed to do to resolve the problem, no computer work needed.
JimG91YJ is offline
post #10 of 14 Old 07-21-2014, 06:38 PM
JMickey
Ok. So what exactly were you told to do to resolve the issue?
JMickey is offline
post #11 of 14 Old 07-22-2014, 02:11 AM Thread Starter
JimG91YJ
remove the locating ear on the distributor and "sinc" the timing(with engine running at 2,000rpm turn distributer to the left, mark where it starts to break-up, same thing to right, center it between the marks and tighten down), loosen the rocker arms by shiming underneath (if it's quiet it's too tight), replace injectors with 24lb injectors, replace spark plugs with autolite 3924 plugs.
JimG91YJ is offline
post #12 of 14 Old 07-22-2014, 06:44 AM
jsawduste
2006 YJ Wrangler
Your kidding right ? Zack and 505 are one of the biggest jokes/hacks and rip off artists in the world of vendors.
jsawduste is offline
post #13 of 14 Old 07-22-2014, 05:36 PM Thread Starter
JimG91YJ
I can't complain, what he told me to do worked.
I've called ATK several times and still havent talked to anyone that could help.
JimG91YJ is offline
post #14 of 14 Old 07-22-2014, 08:02 PM
jsawduste
2006 YJ Wrangler
Sorry Jim but ATK isn't known for stellar service ether. Not whining but simply stating well established and earned facts from within the stroker world.
Indexing the distributor is better done at idle where you can more readily feel and hear the engine begin to stumble then when it is racing at 2,000 RPM.
The Autolite 3924 plug is a projected tip plug with roughly the same heat range as the typical Champion R*12`s. You might consider going to non projected tip plug if you have any signs of detonation. In some cases a slightly colder plug is also helpful in avoiding deto. Such as Champion R*11`s.
Your ATK engine should have come with 24 lb injectors. If not I would be asking ATK why. Typical fuel pressure should be around 39-43 psi with the vac line connected and engine idling
Good luck with your new stroker !!.
