91 YJ Restoration w/PICS* - Page 7 - JeepForum.com
post #91 of 359 Old 04-08-2011, 12:29 PM
merckx9
I want to see how your frame turns out. I am doing my frame this summer and am torn between POR 15 which did a great job on my driver side floor pan and Chassis Saver. Your question about getting POR into the bolt holes is something I would have asked too.
When I was 20 I knew everything, when I was 30 I knew something, at 40 I know nothing!
merckx9 is offline
post #92 of 359 Old 04-08-2011, 01:07 PM
imstillatwork
I second the soft earplug method for threaded holes and paint.
I also think you're batcrap crazy for attempting to stop all that rust! I run away from rust
imstillatwork is offline
post #93 of 359 Old 04-08-2011, 01:52 PM
firefighter315
Originally Posted by hotelconucc93 View Post
LOL. Use marshmellow earplugs! I bought about 30 at Ace, for a quarter a piece. Clean, prep, then squeeze them and insert in the holes. Later, when dry, pull em out. I did this for POR and Herculiner. Even if they don't pull right out easy, you can poke through with a screwdriver or just screw the blt in the remaining foam in the cracks and it will clean it out for you.
Man, that's expensive for those. I get mine at Lowe's....100 for like 15 bucks.
Great idea though!
My YJ Build Thread
firefighter315 is offline
post #94 of 359 Old 04-08-2011, 03:41 PM
hotelconucc93
hotelconucc93's Avatar
2010 YJ Wrangler
For those that care, this photo shows mine after a complete cleaning and acid wash....followed by POR-15 2 coats and a cap coat of Chassis Coat Black. The D30 was POR-15 2 coats.
I was very happy with the finish. Glare doesn't help it, but you get the idea.
LET IT CURE after the chassis coat for about a week. Day 2-5 will be dentable with a finger nail pushed into it. Day seven will break your finger.
Axles and bolts and springs....Oh My!
My Build Thread --->>>
Not my write up, but now one of my jeeps losing a BA and gaining an AX->
hotelconucc93 is offline
post #95 of 359 Old 04-08-2011, 06:42 PM
W_A_Watson_II
My experience with applying POR15 to my M36's frame, is mixed. It was sand blasted, and washed with the POR pre-paint chemicals, but the POR15 has pealed off any place the frame was in clean smooth condition. Where there was rust and pitting, the POR has stuck and stayed.
Will Watson
1993 Jeep YJ 4.6L Stroker (jeep.wawii.com)
1946 & 49 Dodge Power Wagon, 1953 Dodge M37
W_A_Watson_II is offline
post #96 of 359 Old 04-08-2011, 06:48 PM
jeeepguy
jeeepguy's Avatar
Don't bother with POR-15. Use Rust Bullet... much better product.
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline
post #97 of 359 Old 04-09-2011, 07:58 PM Thread Starter
Boss_hog
That's good cause my whole frame was pitted
Boss_hog is offline
post #98 of 359 Old 04-09-2011, 08:03 PM Thread Starter
Boss_hog
Okay,
Finally some serious progress today. Man was it nice here. Worked the whole day on the jeep. The frame is all painted with por 15. It looks 100 times better. I'm very happy man today. Finished the last coat of paint right when the sun went down. Finished just in time.
I'll post yall some pics of the frame once I have the axles painted too
Thanks for reading
Boss_hog is offline
post #99 of 359 Old 04-10-2011, 03:29 PM Thread Starter
Boss_hog
I couldnt resist showing you guys some before and after pics of the frame. I am really happy with the way it turned out. Hopefully this stuff will last.
Today was 80 degrees in chicago. Some serious motivation for me to get this thing in driveable condition ASAP. I want to use this for summer time.
Boss_hog is offline
post #100 of 359 Old 04-10-2011, 03:37 PM Thread Starter
Boss_hog
and some more...
now its time to start working on the tube and to tackle that rust
Boss_hog is offline
post #101 of 359 Old 04-15-2011, 12:28 PM Thread Starter
Boss_hog
Man if someone hot me before i did this resto there would have been just a giant pile of rust
Boss_hog is offline
post #102 of 359 Old 04-15-2011, 12:28 PM Thread Starter
Boss_hog
Hit*
Boss_hog is offline
post #103 of 359 Old 04-15-2011, 12:59 PM
Newk76
I will be following to see your progress, we're picking up our 91 YJ in the morning. I don't think she needs as much as you're doing but it'll be interesting to watch just in case!
Newk76 is offline
post #104 of 359 Old 04-15-2011, 05:17 PM Thread Starter
Boss_hog
good luck with the new jeep
Boss_hog is offline
post #105 of 359 Old 04-16-2011, 07:22 PM
Newk76
thanks,we got her home and are very happy with it. I've stripped out the carpets & cleaned up the interior while the hub did some work under the hood. We had a semi-productive day considering it was raining.
BTW, my husband is lovin the avatar
Newk76 is offline
94 YJ Restoration ...PICS !!! theboxman71 YJ Wrangler Technical Forum 1064 08-19-2017 04:55 PM
First pics of my '95 restoration.... tomesd YJ Wrangler Technical Forum 122 03-25-2011 04:10 AM
Rubi Rim Restoration? (Pics) TJamz TJ Wrangler Technical Forum 13 12-14-2009 10:31 AM
Paint Restoration (lotsa pics) tclaremont Wrangler General Discussion 13 08-14-2009 05:48 AM
Some pics of my 91 YJ restoration YJBlues YJ Wrangler Technical Forum 5 12-23-2005 08:20 PM
