91 YJ Restoration w/PICS* - Page 4 - JeepForum.com
post #46 of 359 Old 03-28-2011, 07:53 PM
jeeepguy
jeeepguy's Avatar
Brake equalizer is a dealer part only. Unfortunately, no one in the aftermarket has made these.
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline
post #47 of 359 Old 03-29-2011, 07:13 AM
hotelconucc93
hotelconucc93's Avatar
2010 YJ Wrangler
No they make them.
http://www.oconeeoffroad.com/servlet...h-BRAKE/Detail
If you buy here, you use their codes and get free shipping...or you look for the same part on Ebay sold by same guy and pay less, but then pay shipping. Up to how you work your internet buying.
Axles and bolts and springs....Oh My!
My Build Thread --->>>
Not my write up, but now one of my jeeps losing a BA and gaining an AX->
hotelconucc93 is offline
post #48 of 359 Old 03-29-2011, 07:18 AM
hotelconucc93
2010 YJ Wrangler
I would also note that you can find the part sometimes when looking through jegs or summit. I found a similar part there as far as the forward cable goes. You can also use that parts list and cross reference part number with either your local stealership or the mopar vender under the JF vendor link or use moparonlineparts for a discount there too.
Local guy here quotes on the forum in the vendor area I believe.
post #49 of 359 Old 03-29-2011, 07:22 AM
hotelconucc93
2010 YJ Wrangler
wyckoffparts is listed under Vendor Display and has a thread going full steam or you can use his web site
post #50 of 359 Old 03-29-2011, 08:06 AM
MrJohn
http://www.motortrend.com/cars/1991/...lls/index.html
Not sure if it's the same part, but there was a parking brake recall. If you're PO hasn't gotten any recalls, I would get them.
MrJohn is offline
post #51 of 359 Old 03-29-2011, 09:03 AM
jeeepguy
jeeepguy's Avatar
My mistake... I've looked before and never found anything but the dealer part.
Doug Patton
Revelation 13:16-18
Think about it...
jeeepguy is offline
post #52 of 359 Old 03-29-2011, 09:05 AM
g4x4xgeoff
I'm subscribed for two reasons.
1) you have as much rust as I did, and I love seeing how people tackle it.
2) your avatar makes me feel all warm inside.
Originally Posted by Hurley91 View Post
I could be drunk, high, raped and almost dead.... and I could still recognize it.
g4x4xgeoff is offline
post #53 of 359 Old 03-29-2011, 12:26 PM
hotelconucc93
2010 YJ Wrangler
Good point. Before I tore mine apart I took it in to the dealer so that they would do the gas tank seal and the parking brake. Theory on the gas tank seal was that they would go through the hell to loosen it up and put the new gasket where I could get to it, and the parking brake assy so I would have a new one to build around.
The parking brake recall is only for the pedal & mount, not the equalizer, so no joy there. They didn't even bother to adjust the parking brakes when I had it done. They just pulled old one and put in new one. Glad because pull handle on the old one was broken off
So when I pulled the tank I had a fresh rubber seal and it came off fine, and the brake got "fixed". Still, you gotta check what was donebut you gotta drive it in me thinks...
post #54 of 359 Old 03-29-2011, 12:53 PM
MrJohn
Ah, just the pedal and mount. I'd definitely still try to check what was done like he said, it's free.
MrJohn is offline
post #55 of 359 Old 03-31-2011, 08:26 AM Thread Starter
Boss_hog
No worries. Were you able to get the stuff I recommended?
Yeah got it all
Boss_hog is offline
post #56 of 359 Old 03-31-2011, 08:32 AM Thread Starter
Boss_hog
Lift ideas
Okay I'm almost ready to paint the frame should have an update on Sunday. I am thinking about buying a black diamond suspension lift from quadratic. Im going to go with the 1.5 inch lift. Also I am going to get the 1 inch daystar body mounts.
Any thoughts, opinions, comments on the lift kit? I don't want to put money into other things like regearing , drive shaft, etc. So that's why I'm doing the 1.5 inch lift. I have 31s tires right now that are in good shape. But any thoughts on the black diamond lifts?
Your .02 cents matters to me
Boss_hog is offline
post #57 of 359 Old 04-03-2011, 02:01 PM Thread Starter
Boss_hog
Update
Didnt get to paint the frame this weekend
Bumbed out cause it would have been nice to have seen some serious progress. I am hoping to get finished with this by the summer. Here are a few pics to where Im at...
One of the body mounts needed some repair. The metal was really thin. So I welded a piece of metal on top of it and the drilled a hole threw it. Happy with the results.
Also a pic of my pops helping me out
Boss_hog is offline
post #58 of 359 Old 04-03-2011, 02:15 PM Thread Starter
Boss_hog
Update #2
Here are some pics of the before and after of the front passenger side frame. This was the only weak spot on the frame surprisingly. This would have been scary if I was driving down the street and didnt have it fixed
I think it turned out well hopefully it will hold up
Boss_hog is offline
post #59 of 359 Old 04-03-2011, 02:28 PM Thread Starter
Boss_hog
Update #3
Last one for the day I swear
Okay so I'm totally getting overwhelmed with this. What did I get myself into. No one I know thinks I am going to finish this Booo. I bought some 91 jeep manuals on ebay though so Im feeling alittle better about it. Just nervous.
I think im finally down with grinding the frame too. Man I think I have rust in my veins now. I am soo sick of grinding looking forward to start on the body sooon
Do you guys think i need some new body mounts, Fenders, and A Dash or what??
I am pretty sure I am going to buy a custom Dash from Double D Fab. He looks like he does good work.
Boss_hog is offline
post #60 of 359 Old 04-03-2011, 02:38 PM
Toms87
1987 YJ Wrangler
FWIW, I haven't heard anyone ever recommend a Black Diamond lift, but maybe that's because not many people have them...? I've got my eye on a BDS kit if my Rough Country springs start sagging too much. They (BDS) have a no questions asked warranty.
Here's the 2". Again, I have no personal experience with their products but hear good things.
http://bds-suspension.com/product?ma=7&mo=32&ty=34&yr=1987-1995
BDS Suspension is not the same as Black Diamond Suspension but people on the forum get it confused sometimes.
Toms87 is offline
94 YJ Restoration ...PICS !!! theboxman71 YJ Wrangler Technical Forum 1063 08-15-2015 04:39 AM
First pics of my '95 restoration.... tomesd YJ Wrangler Technical Forum 122 03-25-2011 04:10 AM
Rubi Rim Restoration? (Pics) TJamz TJ Wrangler Technical Forum 13 12-14-2009 10:31 AM
Paint Restoration (lotsa pics) tclaremont Wrangler General Discussion 13 08-14-2009 05:48 AM
Some pics of my 91 YJ restoration YJBlues YJ Wrangler Technical Forum 5 12-23-2005 08:20 PM
