91 YJ - purchased new, sold, just bought it back - Page 2 - JeepForum.com
post #16 of 130 Old 12-20-2012, 01:34 PM Thread Starter
jeep63
jeep63's Avatar
Progress is slow, but steady...
After describing my transmission housing cracks to MeanMax I pursued a new/used transmission. I found a 94 w/110k miles on it and an NP231 w/SYE for $300.00. This transmission has an external slave, so I need to purchase one of those now.
I also need to find a buyer for my brand new internal slave and a used internal slave in good condition.
My OME springs have arrived and I am itching to put everything back together.
I just finished painting the frame, axle housings, GTSP, and transmission skid plate w/POR15. I have to apply the self-etching POR15 primer and then the POR15 Chassis black. Once that is done I can start re-assembly.
Here are some shots of the POR15 coat:
axles
frame
Skid plate
Gas Tank Skid Plate
Hoping to make some headway over the Christmas holiday...
jeep63 is offline
post #17 of 130 Old 12-20-2012, 03:33 PM
Fuzzy_Wuzzy
Are you sure those are cracks in the transmission and not just casting marks? Those look kind of like typical heat check in a mold. verify that those do not actually protrude out of the transmission.
Either way sounds like you got a good deal on a much less use transmission (plus you can convert to the external slave and SYE++)
Fuzzy_Wuzzy is offline
post #18 of 130 Old 12-21-2012, 06:55 AM Thread Starter
jeep63
jeep63's Avatar
This is a thought I had too. When I ran across the tranny/xfer case combo on Craigslist, I jumped on it. It will be nice to have a tranny with half the miles, an external slave, and have an SYE.
I just found an used external slave for $70.00 complete from master to slave, so all I need to purchase is a new rear drive shaft.
jeep63 is offline
post #19 of 130 Old 12-27-2012, 10:00 AM Thread Starter
jeep63
jeep63's Avatar
re-assembly has begun!
I have the transmission, transfer case and skid plate back on. I have to say again the transmission jack adapter I purchased is one of the best tools I have. I was able to put the transmission back in by myself.
I removed the 2" body lift and replaced it with the 1" poly lift w/integrated bushings. This went smoother than I thought given the age of the Jeep.
My gas tank straps are shot and my plans to re-use them did not work out. I'm waiting for my new ones to arrive today so I can put the gas tank back up. Then I get to install the OME lift!
jeep63 is offline
post #20 of 130 Old 12-30-2012, 10:48 AM Thread Starter
jeep63
jeep63's Avatar
Gas tank is back on.
Replaced fuel filter and installed new bump stops.
OME springs are on too! I have to say the OME bushings do not come with enough sleeves, so I ended up using a set of black poly grease-able ones I had laying around.
I installed front tow-bar shackles so I can flat-tow this to the beach.
Anyone need some Yellow OME bushings? I have four sets.
I also swapped out the old Clutch master/slave for a nused external slave/master setup. I need to order one of the threaded studs for the bellhousing before I can mount the external slave. I am sure that will be a "dealer item".
Rear brakes are back on. I still need to make new rear hard lines and install my new steel braided front lines before I can bleed the brakes.
I am hoping to find some of the OEM 5-star aluminum wheels with "Jeep" stamped on one of the stars. I like those wheels, and I have a message out to a guy on Craigslist who has 5 for sale.
Next up is re-installation of the tie rod, drag link, front drive shaft, track bar and sway bar.
jeep63 is offline
post #21 of 130 Old 12-30-2012, 11:33 AM Thread Starter
jeep63
jeep63's Avatar
Forgot to upload the latest pic...
jeep63 is offline
post #22 of 130 Old 12-30-2012, 07:35 PM
Chrisnvegas
Chrisnvegas's Avatar
Really nice work.
I love this thread. I used to look for my CJ7. I really miss it. I hope I end up liking my Wrangler as much as I love my old CJ7.
And I'm looking for some spring bushings by the way.
Chrisnvegas is offline
post #23 of 130 Old 12-31-2012, 06:00 AM Thread Starter
jeep63
jeep63's Avatar
Originally Posted by Chrisnvegas
Really nice work.
Thanks. I will PM you with the specifics about the bushings
jeep63 is offline
post #24 of 130 Old 12-31-2012, 06:41 AM
ashland82391
a true love story
ashland82391 is offline
post #25 of 130 Old 01-03-2013, 10:48 AM Thread Starter
jeep63
jeep63's Avatar
Score!
I also went to the dealer today over lunch to pick up a stud for the external slave; the bell housing I got only had one in it. I also was told the Nuts used to mount the external slave are no longer available. Anyone know the specs on these? I plan on stopping by the hardware store after I pick up the stud, so I can get nuts, washers, etc...
There is also a "spacer" mentioned that goes between the external slave and the bell housing. This is also no longer available. Anyone know how thick this space is?
Here is a shot of what I am talking about.... see Item 6...
jeep63 is offline
post #26 of 130 Old 01-03-2013, 10:57 AM
Andywear
Wow!!! Very awesome!!!
Used to have a good sig but Mod threated to ban me...
Errrrrrr, Will complain else where - &y
Andywear is offline
post #27 of 130 Old 01-03-2013, 12:22 PM
Que89YJ
Ask Max. If anyone knows he would. Awesome!
Que89YJ is offline
post #28 of 130 Old 01-04-2013, 06:42 AM Thread Starter
jeep63
jeep63's Avatar
Yeah, I have a question out to Max.
jeep63 is offline
post #29 of 130 Old 01-04-2013, 11:02 AM
Que89YJ
Max is busy. I wish his shop was closer. His shop is down in Florida. He has more knowledge then any other person I have ever met on the Jeeps.
Que89YJ is offline
post #30 of 130 Old 01-04-2013, 11:29 AM Thread Starter
jeep63
jeep63's Avatar
I am sure. I met Max at his shop back in November. My family frequently visits the part of Florida where Max's shop is. He is a great guy and I wish my Jeeps were in Florida and not MD.
jeep63 is offline
Sold my soul...now I'm (we're) buying it back gquinzi Wrangler General Discussion 2 09-05-2012 08:36 PM
Sold my Jeep...bought another TIMXJ YJ Wrangler Technical Forum 11 09-04-2011 11:23 PM
Sold my 01 Sport and bought an 05 Rubicon! zerocool333 Wrangler General Discussion 3 01-10-2011 06:40 PM
Sold LJ bought a 07 JK Unlimited.. Time to build irishgearhead JK Wrangler Technical Forum 14 09-24-2009 04:58 PM
Purchased new tinted back windows - did you do the front yourself? myrockfight TJ Wrangler Technical Forum 19 06-29-2006 02:16 AM
