91 YJ Door closing problem - JeepForum.com
post #1 of 7 Old 04-24-2013, 06:33 AM Thread Starter
j_colella1
Hi, My driver side door is not locking when closed. I removed the door panel inspected the links and everything looked good.. I also even took out all links and they were in good shape. When I close the door and the two latches go around the strike pin they do not lock in place to keep it closed. This happenes whether it is locked or not. It just pops out again.
The top half of the latch can easily be moved back and forth. The bottom is very difficult to move. The other door that works fine, both are difficult to move.
Is there a fix or do I need to order a new part?
Thanks
j_colella1 is offline
post #2 of 7 Old 04-24-2013, 07:08 AM
Rproject
1987 YJ Wrangler
If you have the door open, and manually close the jaws, can you lock/unlock the door? You can use a big screw driver to mimic the striker pin for testing with the door open. If it works properly with the door open, start looking at the striker pin and the hinges. Misaligned/bent hinges will create all kinds of binds and cause the lock/latch to not work properly.
I don't see any bent parts in the picture. I'm assuming you already lubricated the latch with a high quality silicone or teflon based lubricant? Please, above all else, DO NOT use WD-40 on your locks/latches.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #3 of 7 Old 04-24-2013, 09:37 AM Thread Starter
j_colella1
When open, I can easily move the top latch in & it comes back out on its own, whether the door us locked or not. All the parts are moving inside the door.
post #4 of 7 Old 04-24-2013, 09:52 AM
kostyanj
I had the same problem with mine when I first got it. Just use a good silicon lube on all of the parts and it'll work.
kostyanj is offline
post #5 of 7 Old 04-24-2013, 01:07 PM Thread Starter
j_colella1
I will try to spray it down with a silicon lube and hopefully that works. Thanks
post #6 of 7 Old 04-24-2013, 02:08 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
A few Questions:
1. Does the door seat completely in (flush with the body) and still pop open without moving the handles?
2. have you recently replaced the rubber seals around the door? If so, you may need to move your striker pin out a bit to meet the door so that the "Jaws" can close completely.
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 AutoLockers F/R
YJOTM Sept. 2017
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #7 of 7 Old 04-24-2013, 02:22 PM
Eron
Just fixed the same thing going on with my passenger door. Loosen the top bolts on the door and shim it up or down. Mine was sitting a little low and i raised it just a tad and closes and locks no problem any more. Of course it could be something else, this worked for me.
Eron is offline
