91 yj clunking noise at take off - JeepForum.com
post #1 of 4 Old 04-05-2010, 12:06 PM Thread Starter
arnelio2
I have a 91 yj and there has been a clunking noise when I start off in first. After the initial noise, I can put the clutch in and release it, and there is no noise. To hear the clunk again, I have to roll back or put it into reverse, and then back into first. Any Ideas? It sounds like it is coming from the tc or tranny. Not sure though. Just wondering if this puts up some red flags for anyone... would save me alot of time. Thanks much
arnelio2 is offline
post #2 of 4 Old 04-05-2010, 12:17 PM
idaholtby
Inspect the motor and tranny mount condition. First guess is a bad tranny mount along with the insulator stud (torque arm for the tranny mount). Usually if one is bad, then all are suspect. Meaning, if the tranny mount components are worn out, then likely the motor mounts are shot as well. Best to replace all as a set. If this is the case, replace the motor mounts first while leaving the tranny mount bolts to the skid loose. Then replace the tranny mounts and tighten once the skid is in place. This could also be caused by bad u-joints, track arm bushings, etc... Inspect all of the above. But with your description, the tranny mounts are my best guess.
idaholtby is offline
post #3 of 4 Old 04-05-2010, 08:24 PM
eaglesfan8105
i had the same problem.. tranny mount was shot so when taking off the tranny was twisting over and causing the drive shaft to be at an angle and the u-joint was hitting off the shield above the muffler
eaglesfan8105 is offline
post #4 of 4 Old 04-05-2010, 11:35 PM
MJMPC
Check your u-joints in the rear driveshaft.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
clunking noise? odoyle31313 TJ Wrangler Technical Forum 1 05-09-2009 10:06 AM
Clunking noise. Please Help! Gabagool YJ Wrangler Technical Forum 7 04-04-2009 06:44 PM
clunking noise. need help tuc TJ Wrangler Technical Forum 3 05-13-2008 11:35 AM
Need help with clunking noise!!!! krawler00 TJ Wrangler Technical Forum 1 01-29-2008 10:03 AM
Clunking Noise cygnus3978 TJ Wrangler Technical Forum 3 08-19-2003 09:18 PM
