91 yj charcoal canister replacement - JeepForum.com
 2Likes
post #1 of 27 Old 09-11-2017, 11:16 AM Thread Starter
yj_kid_91
So I've been looking to replace my vapor canister aka charcoal canister. I've found the cp3045 canister and the cp1061 only issue is I'm too late and there all sold out.
Has anyone found one similar or found a canister and retro fitted it to the yj? I have a 4.0l yj if that matters
yj_kid_91 is offline
post #2 of 27 Old 09-11-2017, 12:01 PM
timatoe
timatoe's Avatar
I don't know if it matters between the 4.2 and the 4.0. Here's a thread with some info, somewhere along the way there's a catalog link as well..... http://www.jeepforum.com/forum/f12/v...hange-2492001/
timatoe is offline
post #3 of 27 Old 09-11-2017, 01:26 PM Thread Starter
yj_kid_91
All part numbers listed are no longer available. Not sure which kind is compatible anymore
post #4 of 27 Old 09-11-2017, 03:15 PM
timatoe
timatoe's Avatar
That's odd...
Originally Posted by timatoe View Post
...... I ordered the one listed above (CP1004) from Rock Auto and got it installed...
The CP1004 was not a direct replacement, it's a bigger diameter but works nonetheless. Again, I don't know if the 4.0 and the 4.2 are the same, I would assume you may have to cap off the carb vent port.
More than twice what I paid though..
http://www.rockauto.com/en/partsearch/?partnum=CP1004
44 new currently available on eBay
https://www.ebay.com/sch/eBay-Motors...40&_nkw=cp1004
Otherwise you may have to search the catalog for one that closely matches yours.
http://ecatalog.smpcorp.com/STD/#/se...anister?type=p
Mopar part number is 53030242, tons of those used on various sites.
timatoe is offline
post #5 of 27 Old 09-11-2017, 03:36 PM
bpounds
bpounds's Avatar
Did you try the search tool that I posted in that other thread?
http://ecatalog.smpcorp.com/STD/#/searchparts
It's a little clunky to use. But go to that page, and on the left side, bottom of the list, use the "Product Category (Part Type) Search". Scroll down and select Fuel Vapor Canister. Don't select any specific year or model or any of the other items. Just hit Search, and it will show you a list of ALL of the canisters. There is a ton of them, and you just have to pick through them to find one that you think will work, as far as size, number of ports, it needs a built-in purge valve, etc. I wanted one as close to original size, and cylindrical shape, fit in my mount, and so forth. But the more of these that go out of production, the less selective we can be. Most of them are rectangle instead of cylindrical, and I ignored all of those, but in reality many of them will probably work. You just have to figure out how to mount it, and hopefully your smog check, if any, is not too much like CA.
Searching briefly, I think this one might work. But you need to decide that on your own. I only like to waste my own money, not yours
https://www.amazon.com/Standard-Moto.../dp/B000C7WSZQ
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,CRT HEI Ign,AX15 ext slave conversion, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline
post #6 of 27 Old 09-11-2017, 03:38 PM
bpounds
bpounds's Avatar
Be careful with the used ones. I got burned on that. Mostly what goes wrong with these is the diaphragm in the purge valve gets a hole in it. And resellers don't know how, or don't care, to test them. The charcoal itself never wears out, and the base filter is still available and very cheap.
Bill
bpounds is offline
post #7 of 27 Old 09-11-2017, 03:47 PM Thread Starter
yj_kid_91
I'd rather buy new than roll the dice. That one u bought does it vent on the bottom like factory?
post #8 of 27 Old 09-11-2017, 04:11 PM
bpounds
bpounds's Avatar
I did not buy the one I linked to above. The one I bought is now obsolete.
But yeah, I think most all of the cylindrical ones are open on the bottom. There is some kind of screen or grille that holds a filter in place. They are not sealed canisters. The charcoal just absorbs volatile vapors, and then gives them back when the vacuum turns on and sucks fresh air upward through the charcoal.
Bill
bpounds is offline
post #9 of 27 Old 09-11-2017, 06:24 PM
timatoe
timatoe's Avatar
The one I linked vents on the bottom like the factory, I think most of them do.
timatoe is offline
post #10 of 27 Old 09-11-2017, 07:02 PM Thread Starter
yj_kid_91
I'll dig. The cp3045 doesn't which mean the mushroom cap I could take off and extend all the way to where my diff breather and transfercase breather are located
post #11 of 27 Old 09-11-2017, 08:39 PM Thread Starter
yj_kid_91
I will keep digging but does this look like it could work? I assume the bottom one is a vent nipple and looks like it has a diaphragm. Would it matter which way it was positioned? Hoping to mount up and down like factory
http://ecatalog.smpcorp.com/STD/#/ve.../CP2004?type=s
post #12 of 27 Old 09-11-2017, 08:44 PM Thread Starter
yj_kid_91
I apologize if I keep posting ideas. This one looks like 3 nipples ontop and one at a 45 degree on the bottom. I guess I know I'm looking for 4 nipples one being a vent so I can eliminate any water getting inside. Basing this idea of the cp 3045 which is no longer avaiable.
http://ecatalog.smpcorp.com/STD/#/ve...m/CP450?type=s
post #13 of 27 Old 09-11-2017, 09:12 PM Thread Starter
yj_kid_91
Last post of the night.
Link should be last 4 nipple including vent or breather which ever vents to outside
http://ecatalog.smpcorp.com/STD/#/ve.../CP3174?type=s
http://ecatalog.smpcorp.com/STD/#/ve.../CP3049?type=s
Other ones are of 5 nipples vent included. Which i could always block one hole?
http://ecatalog.smpcorp.com/STD/#/ve.../CP3047?type=s
http://ecatalog.smpcorp.com/STD/#/ve.../CP3035?type=s
post #14 of 27 Old 09-11-2017, 09:20 PM
Dake
Dake's Avatar
I have the original one still ,how often do they need changing? I never smell fuel that I know of
Waiting on my Rough Country lift to sag!
Dake is offline
post #15 of 27 Old 09-12-2017, 07:18 AM
JeepJJ
May not help but I used cp3034 in my 87 2.5. The 87-90 2.5 used the same canister as the 4.2 but the hoses went different places. The cp3034 is a little smaller and the ports are placed opposite. I've had it in installed for like a year or so with no problems. Paid $100 on eBay. Just saw one for $148. No they are not gold plated.
JeepJJ is offline
