91 YJ with a 98 cherokee engine, fuel pressure question - JeepForum.com
post #1 of 11 Old 09-01-2013, 07:58 PM Thread Starter
D0T-C0M
2014 JK Wrangler
My friend bought a YJ with a 4L 98 cherokee engine in it. He has a fuel pump problem and wants to change it but I told him that I believe the YJ 4.0L uses the old injector that run at 39psi. The 98 4.0L should run at 49psi as per the service manual. What does he have to do in order get the proper fuel pressure, adjustable regulator? TJ swap tank?
D0T-C0M is offline
post #2 of 11 Old 09-01-2013, 08:48 PM
stenyeart
Is he running a return line fuel rail or a return less?
I would assume it is a return line and he would just buy the yj pump. Up front you just need to find the correct FPR to keep the rail at 49 psi. The yj pump will keep up just fine with the higher pressure. This is how I did my obd2 4.0 swap. If you need the info on the what FPR to buy, let me know and I can look it up.
stenyeart is offline
post #3 of 11 Old 09-01-2013, 09:28 PM Thread Starter
D0T-C0M
2014 JK Wrangler
I think he told me that there were 2 pipes coming from his tank. I'll ask him tomorrow to see what he has to make sure?
He did say that there isn't a regulator on top up the tank like my TJ. Where is the fuel regulator located on a YJ?
By all means if you have the info on which proper regulator he needs please post it so I can pass the info along to him.
Thanks a lot
D0T-C0M is offline
post #4 of 11 Old 09-01-2013, 10:17 PM
stenyeart
The regulator is on the front of the fuel rail. This is the regulator you need. http://www.naxja.org/forum/showthread.php?t=1043808
Buying one of these will be a lot cheaper than a hesco adjustable regulator and it is a direct bolt in.
Look at the fuel rail. There should be two lines connecting to it at the front of the engine and the FPR located on the same end as the hoses. Of course this is assuming he has the return system. Look at the pic in post #7 here. http://www.jeepforum.com/forum/f12/w...4-0-a-1198259/
post #5 of 11 Old 09-02-2013, 06:34 AM
Que89YJ
It sounds like he is just doing a block swap and he already had it setup for the fuel injection. What year yj is it and did he change out any electronics?
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #6 of 11 Old 09-02-2013, 06:55 AM Thread Starter
D0T-C0M
2014 JK Wrangler
His yj was already fuel injection and he swaped his 91 fuel injection 4.0L for a 98 cherokee engine 4.0L . Everything else is the original wiring.
D0T-C0M is offline
post #7 of 11 Old 09-02-2013, 08:12 AM
Que89YJ
So the only thing he did is swap the block, then the fuel system is the original as well as the electronics. Did he use the 91 fuel rail? The regulator is on the fuel rail on the YJ. Did he put in a temp sensor for the ecu? The 98 block only had one and used it for both the gauges and the ecu. The 91 YJ had a sensor for both and it is important for the ecu to have both. What is his exact issue with the fuel pressure?
Que89YJ is offline
post #8 of 11 Old 09-02-2013, 02:40 PM Thread Starter
D0T-C0M
2014 JK Wrangler
He had told me that the PO had changed the complete engine but I drove over today and it would seem that he only changed the block and is using fuel rail of the 91 so no changes to the regulator is needed. Below is the pics of one of the injectors closeup. Its a
'91-'93
part#33007127
Color:Brown,
Running pressure:39psi,
fuel flow: 21.0lb/hr
Here is his header
The problem he is having is he suspected a bad pump but found that his regulator was faulty because he wasn't getting enough pressure. He wanted to change it but then I asked him if he had the 98 fuel injectors or the 91. He said that they were the 98s. This is where I told him that he would need a different regulator and the stock one wouldn't work. After checking myself, he was wrong.
Sorry for wasting everyone's time.
D0T-C0M is offline
post #9 of 11 Old 09-02-2013, 04:23 PM
Que89YJ
No waste of time. The regulator was bad and the pressure was low? Usually the diaphragm rips and the pressure goes high. It's not a waste for the next person searching for a fuel pressure problem. Thanks for posting the fix.
Fault codes:
No Start:
Que89YJ is offline
post #10 of 11 Old 09-02-2013, 06:12 PM Thread Starter
D0T-C0M
2014 JK Wrangler
Where is the check valve in the fuel system of the 91 YJ? In the pump and/or regulator?
D0T-C0M is offline
post #11 of 11 Old 09-02-2013, 06:25 PM
Que89YJ
It's integrated into the fuel pump. I don't know if you checked it bit you should maintain 20 psi for 20 minutes after shutdown.
Fault codes:
No Start:
Que89YJ is offline
