91 YJ 4 Cylinder Axles into an 89 YJ 6 cylinder? - JeepForum.com
post #1 of 5 Old 05-10-2011, 01:56 PM Thread Starter
rexracer530
I found some cheap 91 YJ 4 Cylinder axles, with I believe 4.10 gears. I want to swap these into an 89 YJ 6 cylinder so I can run larger tires. What problems can I expect? I think there are some differences in the axles by year, but I don't know which years they changed.
rexracer530 is offline
post #2 of 5 Old 05-10-2011, 02:39 PM
Destr0
Should bolt right in. The rear axles changed from non-c-clip to c-clip style in 92 or something, but externally they are the same. D30 was the same for the run of the YJ.
~K
1994 Jeep YJ off road toy
1981 CJ7 SBC 350
2005 KJ Libertyt 4x4 CRD w/ 2.5" Frankenlift DD
Destr0 is offline
post #3 of 5 Old 05-10-2011, 07:50 PM Thread Starter
rexracer530
Sweet. $200 for both axles with everything still attached is a good deal right?
post #4 of 5 Old 05-10-2011, 08:26 PM
Mark05059
yep until the d35 breaks and you can get a ford 8.8 to replace it.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #5 of 5 Old 05-10-2011, 08:33 PM Thread Starter
rexracer530
Yeah I'm still keeping an eye out for a 8.8 with the proper gearing.
axles , swap , YJ
4 cylinder axles in 6 cylinder 1995 Yj jm1125 YJ Wrangler Technical Forum 13 03-08-2011 08:41 PM
95 4 cylinder axles into 6 cylinder Jeep? jon_gilbart YJ Wrangler Technical Forum 9 02-16-2011 02:37 PM
Removing center console lock cylinder from latch cylinder Dstompe TJ Wrangler Technical Forum 11 06-27-2009 07:01 PM
Cylinder 2 misfire dead cylinder plenty of fuel Mel16m TJ Wrangler Technical Forum 10 11-27-2007 10:52 AM
Clutch, Master Cylinder, and Slave Cylinder replaced and problem not solved.... loudog3114 TJ Wrangler Technical Forum 7 08-31-2005 08:37 AM
