'91 Wrangler YJ wont go into 5 gear; HELP! - JeepForum.com
post #1 of 5 Old 06-02-2013, 09:13 AM Thread Starter
YJStinker
I have 2.5 YJ 91 Jeep Wrangler with 5-speed manual that won't go into 5 gear any more for some reason. Is anyone familiar with this issue? Here is what's going on:
All of the other gears work well including reverse.
The problem happened when I shift to 5 gear from 4 gear, the engine just revs and 5 gear is not engaged. This is a big issue when on the high way; I can only go to 4 gear.
Any trouble shooting or help would be great! Thanks!
YJStinker is offline
post #2 of 5 Old 06-02-2013, 09:19 AM
gunshw301
Common problem. You will need to remove transmission and replace 5th gear retainer with one of these. http://www.allstategear.com/AX5%205t...20RETAINER.htm
Search ax5 fifth gear and it will turn up any sources to getting it fixed.
F/S Dana 35, 4:10, open make an offer, local pick up only, will not ship. 3-8-13
gunshw301 is offline
post #3 of 5 Old 06-02-2013, 11:37 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
http://www.jeepforum.com/forum/f12/a...emoval-908252/
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #4 of 5 Old 06-02-2013, 02:51 PM
dtn8tr
And then the super source chimes in...Mean Max to the rescue again!
1997 TJ, 5" IRO front with 4.5" HD IRO WJ rear, 35x12.5x15 Mickey Thompson MTZ, JKS disconnects
dtn8tr is offline
post #5 of 5 Old 06-02-2013, 03:12 PM
gunshw301
Aww come on max! First post! Wanted the op to do a little leg work!
Oh, and welcome to jeepforum.
