91 wrangler YJ firewall?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 91 wrangler YJ firewall??
G2 Disc Brake Conversion Kit for Jeep Wrangler YJ TJ LJ ChSavvy Billet LED Tail LightsFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 01-07-2015, 10:04 AM   #1
jordanc91
I have a 91 wrangler and I need to pass an 8 gauge power cord for my amp from the battery through the firewall into the inside of the Jeep. I cannot find anywhere to do this. There is hard plastic seals like everywhere and any forum i find is the newer models that have firewalls so it doesn't help. Anyone have any idea how to do this?? Please help and thank you
jordanc91 is offline   Reply With Quote Quick reply to this message
Unread 01-07-2015, 10:31 AM   #2
89yjislanderr
i'd just drill a hole.
89yjislanderr is offline   Reply With Quote Quick reply to this message
Unread 01-07-2015, 11:15 AM   #3
jordanc91
Would that affect any part of the car? And what do you use to drill a hole through metal?
Unread 01-07-2015, 11:18 AM   #4
CrawlingForward
Drill a hole and pop one of these in. They work awesome!
(Drill with a hole-saw)
http://www.amazon.com/Daystar-KU2004.../dp/B004K2285E
My Other Jeep Is A Jeep - Crawlingforward's Jeep-Related Adventures
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
- North Shore Jeep Club -
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is online now   Reply With Quote Quick reply to this message
Unread 01-07-2015, 11:58 AM   #5
89yjislanderr
it wont affect anything as long as you dont snag any wires or anything. just use a power drill and a bit the size you need. the fire wall's pretty thin- a wood bit would suffice.
Unread 01-07-2015, 12:20 PM   #6
Gealii
Just drill a hole through the firewall and fill the hole with a rubber grommet. I put 8ga through my firewall just behind the brake pedal to power my added fuse block
Gealii is offline   Reply With Quote Quick reply to this message
Unread 01-07-2015, 01:17 PM   #7
jordanc91
Thanks alot! I really appreciate all the help guys
Unread 01-07-2015, 01:36 PM   #8
HaskiE
HaskiE's Avatar
these work great for drilling holes in sheet metal:
http://www.harborfreight.com/3-piece...lls-91616.html
#theneverendingaxe
HaskiE is offline   Reply With Quote Quick reply to this message
