91 Wrangler Defroster Trouble - JeepForum.com
post #1 of 5 Old 04-06-2008, 07:19 PM Thread Starter
PFP
I hope someone can help me with this problem. I have a 91 Wrangler. The defrost/heat lever will not remain in the OFF position. It is kinda spongey. If you force it over to OFF, it kinda springs/slides back over to defrost. Of course in this condition, the defrost wants to run all the time. The only solution so far is to run it in vent, but that is a problem when it is cold. Does anyone know off an adjustment to fix this? I am not wanting to pull the unit since I have an A/C unit under the dash.
Thanks!
PFP is offline
post #2 of 5 Old 04-06-2008, 07:45 PM
atthemattin
1987 YJ Wrangler
wire up a fuse to it or a switch, then pull/switch it off when youdon't want it on
atthemattin is offline
post #3 of 5 Old 04-06-2008, 07:56 PM Thread Starter
PFP
Interesting Idea. Any idea where I could wire that?
I did look at the cables under the dash, could these be adjusted somehow?
PFP is offline
post #4 of 5 Old 04-06-2008, 08:24 PM
Bob_R
How about pulling the control out and checking all the cables. There are keepers on the cable where it attach's to the controls, sometimes these come off. Also look on the underside and make sure no wires are pushing it back. Oh, you have AC, all this is going to be behind the AC unit, except for the controller of course. Something is interfering with the movement, find that.
GROWING OLDER IS MANDATORY, GROWING UP IS OPTIONAL TREAD LIGHTLY
Bob_R is offline
post #5 of 5 Old 04-07-2008, 04:45 AM Thread Starter
PFP
I'm gonna put new carpet in this week, guess I'm gonna have to remove the seats and just fiddle with it. Thanks
PFP is offline
95 Wrangler Rear Defroster? GreyfoxVt YJ Wrangler Technical Forum 13 09-19-2015 06:29 PM
87 Wrangler carb trouble RH31379 YJ Wrangler Technical Forum 9 05-04-2007 07:49 AM
95 Wrangler having trouble staying on. Darkkiller922 YJ Wrangler Technical Forum 4 12-07-2006 05:04 PM
trouble with my wrangler tollo2000 TJ Wrangler Technical Forum 8 07-06-2004 02:29 AM
Wrangler trouble shooting RedBug YJ Wrangler Technical Forum 20 05-03-2004 10:49 AM
