91 won't start in cold weather? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 91 won't start in cold weather?
Income tax season is upon us. We got what u needGet 5% Back On Rugged Ridge-Omix-ADA-Alloy at ExtremeTerraGibson Exhaust Rebate - ExtremeTerrain!
Unread 01-06-2008, 11:34 AM   #1
medtech
I have a 91 yj. 4.0L. Engine is basically stock. When it's warm out, say above 50, the jeep starts fine. When it's cold it won't start. The engine will crank but there is no spark and no fuel.
Could it be the ecu? I would try a new one but they're rather expensive and I still don't know if this would fix the problem.
Sometimes when it's around 50 the check engine light will flicker very rapidly and I can hear a relay clicking. After a minute the light will come on solid and then the jeep will fire right up. Is there some other sensor that might be temperature sensitive that would cause the ecu to shut down the engine and not allow it to start?
Thanks for any help!
medtech is offline   Reply With Quote Quick reply to this message
Unread 01-06-2008, 12:03 PM   #2
Jeeples
Jeeples's Avatar
It's possible that it may be the ECU, however a less expensive part to replace would be your Crankshaft Position Sensor. I would suspect this is to be problem since you are not getting any spark or fuel.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Build Thread
Originally Posted by wjjeep19 View Post
It is what Jeeples has stated.
Jeeples is offline   Reply With Quote Quick reply to this message
Unread 01-06-2008, 04:30 PM   #3
medtech
I've tried a new crank sensor and made sure all relays work correctly. I'll have to try a new ecu. It looks like a pain in the butt to get out, I'll have to remove the washer fluid botle too!
Unread 01-06-2008, 05:24 PM   #4
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
next time try a search and read the FAQ first. I know it's long but it's got what you need in this case:
http://www.jeepforum.com/forum/f12/91-hard-no-start-long-cranks-cold-explained-490788/
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline   Reply With Quote Quick reply to this message
Unread 01-06-2008, 08:28 PM   #5
medtech
Excellent. Sorry for wasting your energy making you type the link!
