91 won't start in cold weather? - JeepForum.com
post #1 of 8 Old 01-06-2008, 10:34 AM Thread Starter
medtech
I have a 91 yj. 4.0L. Engine is basically stock. When it's warm out, say above 50, the jeep starts fine. When it's cold it won't start. The engine will crank but there is no spark and no fuel.
Could it be the ecu? I would try a new one but they're rather expensive and I still don't know if this would fix the problem.
Sometimes when it's around 50 the check engine light will flicker very rapidly and I can hear a relay clicking. After a minute the light will come on solid and then the jeep will fire right up. Is there some other sensor that might be temperature sensitive that would cause the ecu to shut down the engine and not allow it to start?
Thanks for any help!
medtech is offline
post #2 of 8 Old 01-06-2008, 11:03 AM
Jeeples
Jeeples's Avatar
It's possible that it may be the ECU, however a less expensive part to replace would be your Crankshaft Position Sensor. I would suspect this is to be problem since you are not getting any spark or fuel.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #3 of 8 Old 01-06-2008, 03:30 PM Thread Starter
medtech
I've tried a new crank sensor and made sure all relays work correctly. I'll have to try a new ecu. It looks like a pain in the butt to get out, I'll have to remove the washer fluid botle too!
medtech is offline
post #4 of 8 Old 01-06-2008, 04:24 PM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
next time try a search and read the FAQ first. I know it's long but it's got what you need in this case:
http://www.jeepforum.com/forum/f12/91-hard-no-start-long-cranks-cold-explained-490788/
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #5 of 8 Old 01-06-2008, 07:28 PM Thread Starter
medtech
Excellent. Sorry for wasting your energy making you type the link!
medtech is offline
post #6 of 8 Old 11-16-2016, 08:51 AM
tonyac17
I have read the post that you posted about jeeps not starting in cold weather. My issue is just a little different than the one you posted. Mine is a 2006 Jeep wrangler RHD. In the summer it will start fine. No problems. When is gets under 45 degrees it wont start. When I say wont start it will turn over once and and then you have to turn the key to the off position and then back on again. If you do this about 25-50 times it will start or when the temperature outside raises a little it will start on about the 5th try. We took it to the jeep dealership last week thinking they would be able to fix the problem. $300 and a new crankshaft sensor later still will not start. If we park it in the garage and run a heater it will start. I deliver mail so I never know when I can get called in so not able to keep it in the garage with a heater every night. Just hoping you can help me with my problem.
Thanks
Tonya
tonyac17 is offline
post #7 of 8 Old 11-16-2016, 10:54 AM
Que89YJ
Tony you need to post to this forum:
http://www.jeepforum.com/forum/f96/
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #8 of 8 Old 11-16-2016, 04:18 PM
tonyac17
Ok..thanks
tonyac17 is offline
Cold Weather Start - Grinding ten27oh4 JK Wrangler Technical Forum 19 01-04-2011 02:52 PM
Cold Start New to Cold Weather Thexonexkid TJ Wrangler Technical Forum 18 12-02-2009 12:39 PM
Hard to start in Cold Weather Kiwi_TJ TJ Wrangler Technical Forum 4 06-05-2009 06:31 AM
low screeching noise on start up in cold weather jeep n00b YJ Wrangler Technical Forum 8 12-05-2008 01:28 PM
start up problems during cold weather 88JeepYJ YJ Wrangler Technical Forum 2 01-06-2004 02:22 PM
