91 blower motor replacement - JeepForum.com
post #1 of 4 Old 10-18-2011, 06:00 PM Thread Starter
bigpolock
I have traced my heating problems to the blower motor and am a little puzzled as to how to replace the motor. I appears to be sandwiched between the fire wall and the venting shrowed. I hope that this is not the case as I can not find the bolts to remove either. Hoping that someone can shed some light on this case. Thanks.
bigpolock is offline
post #2 of 4 Old 10-18-2011, 06:22 PM
uhohthe50
You will have to take out the whole heater box assembly and Its kind of a pain. From what I remember there were 4 main nuts on the firewall on engine side that held it in (not including the rest of the crap in the way to get it out). You also have to take off the heater core hoses from inside the firewall so you might want to consider changing the heater core while its out. I didn't change mine but most people recommend to. It was worth it in the end for me. I put in a blazer blower motor and it's like 5 times more powerful than the stock blower motor
My 1990 YJ Build Thread: http://www.jeepforum.com/forum/f22/might-well-start-build-thread-now-my-1990-yj-1291174/
uhohthe50 is offline
post #3 of 4 Old 10-19-2011, 02:50 PM
Jones-Maryland
Ditto what uhohth50 said. Be careful if disconnecting the control cables, those plastic fasteners are brittle with age and difficult to find replacement cables. I have not figured out the trick to getting those disconnected. You will have to open the heater box to replace the heater core. Point is do all the maintenance you can while it is out, since there is a lot of disassembly involved in getting to it.
Jones-Maryland is offline
post #4 of 4 Old 10-19-2011, 04:56 PM
Tompatt
1987 YJ Wrangler
search PM102 blower upgrade if you want the upgrade. i think its 87-91 that have the smaller motor IRCC
Thomas
-1987 YJ
Tompatt is offline
97 blower motor replacement? gotmudd1 TJ Wrangler Technical Forum 5 10-01-2009 06:58 AM
Blower Motor replacement mrlbro616 YJ Wrangler Technical Forum 14 01-25-2009 07:44 AM
Blower Motor Replacement JBTJ TJ Wrangler Technical Forum 2 06-19-2008 05:55 PM
Blower motor replacement BChamberlin TJ Wrangler Technical Forum 3 05-15-2008 01:51 AM
Blower Motor Replacement...please help markdonnell1975 TJ Wrangler Technical Forum 6 11-21-2005 12:46 AM
