91-94 ax5 swap - JeepForum.com
post #1 of 10 Old 04-20-2013, 12:21 PM Thread Starter
ecarton
91-94 ax5 swap
Can I use a 91yj ax5 in my 94yj? Is it simply use the 94 bell housing or is there more that needs to be switched? what year ax5 are a direct match for the 94 yj?
ecarton is offline
post #2 of 10 Old 04-20-2013, 03:27 PM
jeep63
jeep63's Avatar
I put a 94 ax5 in my 91, so you should be fine.
jeep63 is offline
post #3 of 10 Old 04-21-2013, 06:20 AM Thread Starter
ecarton
did you keep your 91 bell housing or use the 94? I want to use my 94 bell housing with the 91 tranny so I keep the external slave.
ecarton is offline
post #4 of 10 Old 04-21-2013, 08:55 AM
jeep63
jeep63's Avatar
I used the 94 bellhousing, so I could swap to the external slave. Worked like a charm.
jeep63 is offline
post #5 of 10 Old 04-21-2013, 03:29 PM
flcracker
You have to swap out the bearing retainer also.... the throwout bearing rides on it.... when you pull your old trans off look inside the bellhousing and you will see the difference....
Not the sharpest bulb in the box....
My Jeep is possessed with the goal of making me lose my religion....
flcracker is offline
post #6 of 10 Old 04-21-2013, 05:00 PM Thread Starter
ecarton
Can I use the parts from 94? I found a low mileage 91 in good running order, all 5 gears and no grinding. I am not a mechanic is it a DIY project?
ecarton is offline
post #7 of 10 Old 04-21-2013, 05:26 PM
flcracker
Yes, just pull the bearing retainer off of the '94 and put it on the '91 tranny when you swap out the bellhousing
post #8 of 10 Old 04-21-2013, 07:59 PM Thread Starter
ecarton
Thanks for the help.
ecarton is offline
post #9 of 10 Old 04-21-2013, 08:09 PM
Blackfish
Also replace the tension spring they are cheap but most are brittle and broke you will see it it will fall out when you swap the bearing plates.
My boss made the comment that "I bet you missed me over the holiday break",my response was "yes your right I did, but my aim is getting better"
Blackfish is offline
post #10 of 10 Old 04-23-2013, 08:20 PM Thread Starter
ecarton
Thanks for the tip, I'll pick one up.
ecarton is offline
