904 transmission question - JeepForum.com
post #1 of 2 Old 05-21-2010, 08:24 AM Thread Starter
creekscout
I would like to know if the 904 traansmission in a '94 wrangler with a 4 cyl. has the same bolt pattern as a 2.8 V6 '86 cherokee for the bellhousing so that it would fit in my cherokee. Thank you for any info that can help me.
creekscout is offline
post #2 of 2 Old 05-21-2010, 08:43 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
Check out this thread & look at #3 in the diagram & read the notes. I believe the answer is yes. See what you think.
High Desert Off Road :: View topic - light duty tranny swap bible
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
03 Transmission question gixxer1397 TJ Wrangler Technical Forum 8 02-28-2010 03:35 PM
Another transmission question wranglerwill01 TJ Wrangler Technical Forum 6 09-23-2008 04:14 PM
transmission question jeepwrnglr92 TJ Wrangler Technical Forum 3 06-06-2008 11:27 AM
transmission question rico334 TJ Wrangler Technical Forum 4 01-03-2004 08:00 PM
HELP! Transmission question Alphadux TJ Wrangler Technical Forum 1 01-01-2004 05:07 AM
