90 yj wipers won't work Help!!! - JeepForum.com
post #1 of 12 Old 12-21-2009, 08:34 PM Thread Starter
deadidick
1987 YJ Wrangler
wiper won't work, the fuse looks fine, is there a circuit breaker? is there a way to by pass the switch and check the motor while still on the jeep ? need help rains comming!!!!!
deadidick is offline
post #2 of 12 Old 12-21-2009, 08:59 PM
spawnofsatan
This happen to me once all I did was turn the wiper on and give the wiper arm a little pull and see what happen.
spawnofsatan is offline
post #3 of 12 Old 12-21-2009, 09:01 PM
spawnofsatan
double post
post #4 of 12 Old 12-21-2009, 09:20 PM
havasu
On permanent vacation
havasu's Avatar
My wipers wouldn't work at all. After checking fuses, wires, circuit breakers, etc, I found the problem....an old stereo remote and a large dog choke chain fell thru the windshield vent and wedged themselves around the wiper linkage. If you have voltage to the wiper motor, it might be worth a shot to go fishing and see what you come out with!
havasu is offline
post #5 of 12 Old 12-21-2009, 10:05 PM Thread Starter
deadidick
1987 YJ Wrangler
is there a circuit breaker? if so where is it. i did find a lighter in the frame, i'll do some more fishing tomarrow, thanx Rich
post #6 of 12 Old 12-21-2009, 11:03 PM
SnowdogMarc
There's a box Velcroed or screwed to the dash under the headlight switch area. This is the magic box that controls the wipers. Check the connections on it, I had issues with the intermittent part of it not working and found it by wiggling the wires accidentally. Try cleaning up the contacts on it and see if that helps.
l We're here for a good time. Not a long time. So have a good time the sun can't shine every day.
l_______
/l ,[_____],
l---L -[]lllllll[]-
()_) ()_)--o-)_)____________VE6-SDG
SnowdogMarc is offline
post #7 of 12 Old 12-22-2009, 06:45 AM
havasu
havasu's Avatar
I don't believe a circuit breaker is used for the wipers. If your linkage is fine, and "wire wiggling" didn't work, you might have to lower the windshield to confirm that your wires are not pinched. From that point, you can test for power or replace if needed.
havasu is offline
post #8 of 12 Old 12-22-2009, 06:56 AM
idaholtby
Correct, no c/b. Power supplied by 5.3amp fuse under the dash and it is the middle fuse on the bottom row. Power goes through the switch to the wiper motor. If all of the other suggestions do not pan out, and if you have intermittent wipers, then try bypassing the intermittent module by disconnecting it and connecting the two connectors together to rule out the intermittent control module.
idaholtby is offline
post #9 of 12 Old 12-22-2009, 01:13 PM Thread Starter
deadidick
1987 YJ Wrangler
got them working!!! had to strip the harness to locate several smashed wires . did some cutting and spliceing ,put it all back together and i have wipers. the wife took my yj to work as we woke up to snow. as she walked out the door she reminded me to fix her yj. done deal i might even get lucky tonite! thanks for all your input
post #10 of 12 Old 12-22-2009, 06:54 PM
havasu
havasu's Avatar
Just curious, where were the smashed wires located?
havasu is offline
post #11 of 12 Old 12-22-2009, 11:11 PM Thread Starter
deadidick
1987 YJ Wrangler
under the wind shield. the jeep was laid on it's side by the kid who owened it. his mom was done wiyh it so i picked it up for $500 no body damage . cracked windshield and a broken rear axel shaft. found shaft ,backing plate at the junkyard. bought a new brakedrum and rear brakes. waxed it and it on the road and looking great ,it's a 90 yj 4 banger with 31z10.50x15 brand new tires on it at purchase. i think i have $800 in it, gave it to the wife for xmas. that should keep her from driving my 87yj.
post #12 of 12 Old 12-23-2009, 06:37 AM
havasu
havasu's Avatar
With your luck, you should go to Las Vegas!
havasu is offline
Wipers dont want to work... Steelz19 TJ Wrangler Technical Forum 6 10-01-2007 07:41 PM
Wipers don't work H60framer YJ Wrangler Technical Forum 0 10-16-2006 04:01 PM
Intermittent Wipers Don't Work bryris YJ Wrangler Technical Forum 1 08-21-2006 10:17 AM
Wipers work when they want to rcsdrob YJ Wrangler Technical Forum 5 10-20-2004 10:46 AM
TJ Wipers don't work ... atmel101 TJ Wrangler Technical Forum 2 09-11-2004 11:18 AM
