90 yj will not start - JeepForum.com
post #1 of 6 Old 02-22-2014, 11:06 AM Thread Starter
JMAC90YJ
JMAC90YJ's Avatar
I have a 90 YJ 2.5 5 speed.
It has only sat for abot a week without being started this winter.
Today I tried to start her and nothing, battery is fine no loose battery wires, I cannot even hear the fuel pump kick on, the needle on the amp guage does not move and the only thing that works in the cig lighter,
Please tell me where to start looking.
SOME PEOPLE ARE LIKE SLINKIES - NOT REALLY GOOD FOR ANYTHING BUT THEY BRING A SMILE TO YOUR FACE WHEN THEY'RE PUSHED DOWN THE STAIRS.
JMAC90YJ is offline
post #2 of 6 Old 02-22-2014, 11:17 AM
dancytron
Bad battery cables, especially the big ground cable to the engine. They can look fine and be totally ruined and corroded inside.
Also, follow the small positive cable to the starter relay. It will be on a post with 5 or so 10 gauge wires. Each 10 gauge wire starts with a fusible link. This is the power supply for the whole jeep except for the starter. Clean it up, check continuity of fusible links.
dancytron is offline
post #3 of 6 Old 02-22-2014, 03:41 PM
jaycal3
Fuses and ground.... As stated, check the negative battery cable at the block...
Sent from my iPhone using JeepForum... So excuse the typos, my iPhone is challenged.
93 YJ, 6 cyl,3.5" BDS,1" Prothane BL,1/2" booms, 33" Mickey Thompson MTZ on MT Beadlocks.
Do your part for Leukemia research - help find a cure.
KCCO
jaycal3 is offline
post #4 of 6 Old 02-22-2014, 04:11 PM
rwcook49
rwcook49's Avatar
Agreed. After checking the battery cables and fuses, check the fusible links down on the firewall. If one is blown you won't start.
'90 YJ, 4.0L, Old Man EMU, 2.5" Body, 33" BFG A/T, ARB front and rear, 4.56 gears, Superwinch 9.0c, Mastercraft rubicon seats
rwcook49 is offline
post #5 of 6 Old 02-23-2014, 08:11 AM Thread Starter
JMAC90YJ
JMAC90YJ's Avatar
Eureka
Thanks everyone, I removed main ground wire, cleaned the block stud replaced the ground cable and eureka it worked.
JMAC90YJ is offline
post #6 of 6 Old 02-23-2014, 09:19 AM
jaycal3
Awesome! I only knew the issue might be at the block because I had the same problem. Congrats!
KCCO
jaycal3 is offline
