90 YJ Got spark, got fuel. No start - JeepForum.com
post #1 of 5 Old 06-18-2011, 05:28 PM Thread Starter
Plyj
Okay... this is frustrating. Installed new 4.0L head (new valves, springs, retainers, headers, rocker arms, etc.) on my 4.2L block.
Got TDC on compression stroke (the way I checked this was by watching the valves open while manually turning engine... last valve open before TDC mark hit 0 was intake valve). Have GM HEI which ran great before head transplant.
In fact, everything ran great before transplant.
I'm getting spark (hung light off #1 & cranked engine). I'm getting fuel (looked down throat of Weber & see gas going in when I move throttle).
This should be simple... I've got spark, I've got fuel, and I'm on TDC.
Time to pull timing chain cover??? This thing has me baffled... help!
Plyj is offline
post #2 of 5 Old 06-18-2011, 05:51 PM
giggityjeeper
bad vac leak somewhere, taht would keep it from firing, if it was bad enough....
ground not hooked up somewhere...
dont know man frustrating fro sure this kind of ****
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #3 of 5 Old 06-18-2011, 08:46 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
That intake valve should have been closed (fuel air charge has to be in the cylinder before the compression stroke begins) as you were coming up on TDC of the compression stroke.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #4 of 5 Old 06-18-2011, 09:07 PM
Noltz
YJ Wrangler
^^ beat me too it. Your last valve to open before TDC, and it should close as you approach TDC. If there's a bit of overlap in the cam you might have both valves moving at the same time, @ TDC.
Sounds like you're 180 out.
-Noltz
'91 Frankenheep YJ. 4.0, 4" BDS, Richmond 8.8, Titan 12k, 35" KM2's, rust.
'88 YJ, 4.2/4.0 head, +4" & shackles, BFG 33's (sold)
Noltz is offline
post #5 of 5 Old 06-18-2011, 09:30 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Pull #1 plug...stick finger in plug hole. Have a buddy bump engine until the compression wants to push your finger out of the #1 plug hole. Use breaker bar and large socket to findish bringing this engine up to TDC by sticking long thin stick in #1 hole to watch #1 piston come up to TDC checked against your timing marks. Once TDC on the compression stroke is attained, pull the distributer cap and check rotor position. Move rotor to just before #1 plug tower position on said disrtibuter. Enjoy!
fuel , spark , timing
No spark No fuel No start Mark05059 YJ Wrangler Technical Forum 9 07-05-2009 06:39 PM
Have spark and fuel. No start. bob082484 YJ Wrangler Technical Forum 0 01-17-2009 08:21 PM
spark, fuel, no start??? 97tjeff YJ Wrangler Technical Forum 2 08-05-2008 06:42 PM
Fuel and Spark Still no Start Rebel442 YJ Wrangler Technical Forum 4 07-08-2008 07:50 AM
got fuel, got spark, but it still won't start?? jfallken TJ Wrangler Technical Forum 25 03-28-2005 03:25 PM
