90 YJ fan clutch - JeepForum.com
post #1 of 9 Old 08-23-2011, 02:40 PM Thread Starter
bogleparsons
90 YJ fan clutch
Just wondering what year they started putting the fan clutch on wranglers, I don't have one but would possibly like to upgrade if it fits easily.
bogleparsons is offline
post #2 of 9 Old 08-23-2011, 03:14 PM
Louie4
"You pass butter"
Louie4's Avatar
What do you have on your motor now? Do you have an overheating problem? As far as I know all wranglers have fan clutches but I'm not sure when they started putting thermal vs. non-thermal on them.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #3 of 9 Old 08-23-2011, 03:21 PM
clarkjdg
clarkjdg's Avatar
Well I dont know about the 4's, but my 88 YJ with a 6 has one on it and mine went out a while back and I just told them the year and model and the new one was the same and I figured the 4s did to, maybe someone took it off of yours somewhere down the road in the past and put the one thats there on it.
LIVE EVERY DAY LIKE IS WAS YOUR LAST...
/_|__\___\
[n___n_[*lllll*]
(o) )-(o) )-*-) )
88 YJ, Smittybilt SRC Front, Side, and Rear Armor, Family Roll Bars, TJ Flares, and Half Doors
4"Leaf, 2"Body, and 1"Leaf Lift, 4.10 Geared Dana 30 Posi with Cable Engage, Ford 8.8 Posi, With 33s BFGs MT KM2
Everything "Black" Inner, Under, and outer "Black" on the Body is "Bed Linered" and I will be Thru the day that I Die!
clarkjdg is offline
post #4 of 9 Old 08-24-2011, 05:06 AM Thread Starter
bogleparsons
Know way to tell i suppose but its definitely not a clutched fan, with the engine off if i spin it the whole engine turns, I'm thinking a clutch fan will help it warm up faster in the winter and maybe free up some engine power when not in use.
(2.5L engine power) < lol
post #5 of 9 Old 08-24-2011, 08:06 AM
Que89YJ
LOL you bought a PO jury rig then. All the YJ's had a clutch fan. With the 2.5L that thing is taking a bunch of your horse power. Get rid of it totally and go to the Taurus fan. You will get more horse power and better cooling for under $100. It's well worth it and not much more then the clutch will cost you. I can tell the difference big time with my 89 2.5L.
http://www.jeepforum.com/forum/f13/f...l-pics-233676/
Que89YJ is offline
post #6 of 9 Old 08-24-2011, 09:07 AM
pasinbuy
One way for a fan clutch to go out is that they will lock up. Sounds like your fan clutch locked up.
pasinbuy is offline
post #7 of 9 Old 08-24-2011, 09:12 AM Thread Starter
bogleparsons
Upon further investigation, and looking at some pictures on the web, I do in fact have a fan clutch.
However it is locked up arg. I don't experience an overheat condition in 100+ deg weather so i suppose its something i can live with.
But the idea of a little more power would be nice. I just don't favor adding any electronics on my jeep because i like to play in the water/mud
post #8 of 9 Old 08-24-2011, 09:23 AM
Que89YJ
The electric fan is better by a long shot for mudding and water. The mechanical and electric fan trying to push through the mud and water destroys them. Most people put a kill switch to toggle off the electric fan which is something you just can't do with the mechanical fan. The fan being seized like that is making your engine work way harder then it should eating up your fuel and is trying to push mud and water when you are sloshing the heap in a crossing. You really shouldn't leave it seized up.
Que89YJ is offline
post #9 of 9 Old 08-24-2011, 09:49 AM Thread Starter
bogleparsons
good point, and brings some things up i hadn't thought of.
Thanks for the insight.
Need new clutch slave/master cylinder: Quadratec or clutch city online? Links inside myoung YJ Wrangler Technical Forum 3 08-23-2010 06:49 PM
88 5 Speed - Tranny Not Engaging After Clutch install (no clutch need to shift) kgillette YJ Wrangler Technical Forum 12 11-01-2009 01:39 PM
clutch whirrring/squealing noise - but stops when I press on clutch dirtyjpwrangler JK Wrangler Technical Forum 12 09-28-2009 09:55 PM
Question about destroying clutch plate WITH CLUTCH PEDAL DEPRESSED JeffB TJ Wrangler Technical Forum 12 07-20-2009 11:29 AM
great! More AX5 Clutch problems!!!!! hooray for internal clutch slave cylinders! Big-n-Broke-YJ YJ Wrangler Technical Forum 6 08-19-2008 03:14 PM
