90 YJ coughing & wheezing - JeepForum.com
post #1 of 13 Old 08-30-2014, 06:03 PM Thread Starter
snowplowdog
Today I finished the install of my CB and 12 volt outlet.
Afterwards I had to go to the mini mart, and then the grocery store about 5 minutes from home. Since I did the nutter it's run great, until today. When I left home it started right up, but sputtered every time I hit the throttle. I was in the mini mart for about 5 minutes. When I cam out I started it, backed out of my spot and it died. Then I could barely get it to start. Crank crank crank then it finally started to fire...had to keep my foot to the floor for a minute to keep it running and when it finally would run without dying I was able to drive accross thw street to the grocery store. I was in there for 30-45 minutes & was expecting a fight to get it going & drive home. Suprisingly it fired right up & drove home with no problems. Perfect throttle response & plenty of power.
I'm thinking a piece of garbage in the fuel filter or fuel line somewhere. Sound about right or is there somewhere else I should be looking?
Never attempt anything you don't want to have to explain to the EMT
snowplowdog is offline
post #2 of 13 Old 08-30-2014, 06:10 PM
mike134
You loaded up the jeep with groceries after realizing it may not start? You're very brave!
I'd test the fuel pressure. Go to autozone and borrow the fuel gauge. Could be your fuel pump is going out. Grab a new fuel filter while you're there. Air filter while you're at it if you haven't done so recently.
mike134 is online now
post #3 of 13 Old 08-31-2014, 07:18 AM
Old4X
1990 CJ7
It may have just flooded from heat soak. Common on carbed F head engines. If it doesn't do regularly, don/t sweat it.
Mine will do it on a hot day if I stop for 10 minutes, or so. Stay in the store longer than 30 minutes, and starting is no problem. When it does flood, just do the "flooded engine start procedure" you were taught way back in driver's ed.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #4 of 13 Old 08-31-2014, 09:12 AM
140mower
I agree with Old4x4, mine will do the same thing from time to time..... Funny, I put what appears to be the exact same 12v power outlet with the usb in the same place last weekend....I took mine apart and drilledéscrewed it to the dash, how did you mount yours*
If it wasn't done the hard way, I didn't do it.
140mower is offline
post #5 of 13 Old 08-31-2014, 09:33 AM
Mike Romain
A gas filter in upside down can cause symptoms like that. The filter should sit level with the return line up top so on a hot shutdown any vapours produced get blown off the top of the filter back to the tank rather than vapour locking it.
Mike
Mike Romain is offline
post #6 of 13 Old 08-31-2014, 01:42 PM Thread Starter
snowplowdog
I just drove to Advance Auto to pick up a new filter. Did the same exact thing, sputtered & coughed on the way there and ran fine on the way home. It's never done this before yesterday. Yes, the fuel filter is installed correctly, I made sure of it when I put everything back together after replacing the exhaust manifold.
Does the fuel pressure guage work with a mechanical fuel pump? I thought that only worked with electric pumps?? The pump could be on it's way out, anything is possible. I knew I shouldn't have fixed all that other stuff.....
I just screwed the 12volt outlet to the underside of the dash. It was a PITA to put it back together while it was mounted in the jeep. I had to move my ashtray/lighter over 3" to the right to get the CB to fit, then just mounted the outlet tight to the right of the ashtray. I was thinking of doing an overhead console for the CB but I would rather not have anything up there when the top is off for the summer. The sound bar is already more than I care for.
post #7 of 13 Old 08-31-2014, 01:56 PM
Mike Romain
What kind of shape is the distributor cap and rotor in? Is the gas tank vent hooked up and is the air filter on the vent clear?
Mike
post #8 of 13 Old 08-31-2014, 02:11 PM Thread Starter
snowplowdog
The cap, rotor, plugs & wires are all new, replaced them when I replaced the exhaust manifold 2 weeks ago. The vent is hooked up, I'll have to make sure it's clear.
post #9 of 13 Old 08-31-2014, 03:05 PM
140mower
The hardest part I found was getting that damned led back in it's spot......
To check the fuel pressure on a mechanical pump you want a combination fuel pressure/vacuum gauge, i would also advise becoming familiar with the use of a vacuum gauge on a carb'd engine as it can tell you a lot about engine condition and tune.....here is a very good start on the use of a vacuum gauge http://www.secondchancegarage.com/public/186.cfm...
140mower is offline
post #10 of 13 Old 08-31-2014, 05:23 PM Thread Starter
snowplowdog
Good call on the vent line. Yesterday when I was installing the CB I ran my coax wire in that area to the antenna. I zip tied it to the taillight wires and looks as though I got the vent line pinched in there as well. I'm not sure that will solve the problem since I haven't driven it since cutting it free, but tomorrow I will be taking it for a drive and we shall see.
post #11 of 13 Old 09-01-2014, 09:15 AM Thread Starter
snowplowdog
Found the problem. Electric choke, bad connection. Every time I think I fixed everything the PO did wrong i find something new.
post #12 of 13 Old 09-01-2014, 10:34 AM
mike134
Awesome!
post #13 of 13 Old 09-01-2014, 07:18 PM
140mower
I like those fixes.....they might take a while to find, but cheap to repair... Well done.
140mower is offline
