90 yj chevy 5.3 fuel issues - JeepForum.com
post #1 of 16 Old 09-01-2014, 05:04 PM Thread Starter
clubtahoe
I put a 2008 chevy 5.3 engine with 4l60e trans in my 1990 jeep wrangler yj. the problem I've found is trying to find a fuel 60 psi pump external. i have the 20 gallon tank with no fuel pump in the tank the original pump was in the carb of the 4.2 that came out.i've looked through the threads i just get a headache of the searching. I'm looking for a good pump to use that is waterproof, electric,60 psi, walboro 255 seems like everybody is using. but i guess i need external because of my sending unit. And are the lines on the tanks unit big enough?Im replacing the frame lines to 3/8 and 5/16. Any help on fuel would be very appreciated thanks!
clubtahoe is offline
post #2 of 16 Old 09-01-2014, 06:16 PM
Old4X
1990 CJ7
Have you thought about using a fuel tank from a 4.0 YJ and use a Chevy pump in it? The pump would swap right in
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #3 of 16 Old 09-01-2014, 08:22 PM
95YJLS
In ~2003, Chevy went returnless and built the fuel pressure regulator into the pump. You will only have one line headed all the way to the engine. I'm not 100% sure on size, but whatever stock size was for your engine is what you want. So, your fuel system will be more similar to a TJ 5.3 swap. Pretty universally, the TJ 5.3 guys go with the Walbro 255lph external pump and a WIX 33737 external filter/regulator. Plumb the outlet of the filter/regulator up to your fuel rail, plumb the outlet of your Walbro to the inlet of your WIX, plumb both the Walbro inlet and the return line from the WIX to your fuel tank.
95YJLS is offline
post #4 of 16 Old 09-01-2014, 09:28 PM
JohnRodriguez
edelbrock makes a external universal sump kit, part # 3605, 60 psi. it uses the factory tank, fuel pump to get the fuel up to the sump, then it pressurizes it up to 60psi for the fuel injection. its pretty neat and ill be using it for the upgrade in my dads old 76 F-150 fuel injection conversion.
89 Wrangler, 2.5L TBI, D30 Truetrac 4.56 gear front, Super 35 4.56 gears rear, 31" BFG Mud's, 15x9" weld racing pro-stars XP's, 2.5" rancho and 1.25" shackels, superior axles. rear wilwood disc brakes
2008 wrangler x unlimited. Stone white. Motech 5.3L LS Chevy
JohnRodriguez is offline
post #5 of 16 Old 09-02-2014, 04:51 AM Thread Starter
clubtahoe
I appriciate the help in going to look into the ways you brought up. Thanks again!
post #6 of 16 Old 09-02-2014, 09:30 AM
Randonexplosion
Deplorable
Randonexplosion's Avatar
I had a 4.2 before my swap with the 20 gal poly tank as well. I just installed a sending unit and pump for an 4.0 Wrangler. As 95YJLS mentioned GM did change the regulation system so you would have to address that. I don't know if a pre-03 fuel rail would fit on an 08 Vortec.
Yes the fittings on the Jeep sending unit are 3/8" supply and 5/16" return.
Randonexplosion is online now
post #7 of 16 Old 09-02-2014, 06:38 PM
95YJLS
I believe the injectors also changed with the new returnless system. A pre-03 fuel rail would probably work, but I don't know if it would be any easier or cheaper than the WIX filter/regulator (I believe it's from the C6 Vette).
Take a look at Docked_Wage's swap thread over on LS1Tech:
http://ls1tech.com/forums/conversion...completed.html
Some of his photos have disappeared But still, lots of good info. He went Walbro 255 & WIX filter/regulator for his setup (an '05 flex fuel engine), and said it worked perfectly.
I have an '02ish plain gas engine, so I'm just going to plumb the stock lines to the new engine, if they will reach, and keep the stock fuel pump until it dies.
LT1Swap is a great resource for wiring & engine info, and he does PCM programming for a reasonable price.
http://lt1swap.com/geniv_harness.htm
http://lt1swap.com/identify_vortec_engine.htm
Also note, with an '08 engine you very likely have Displacement on Demand.
95YJLS is offline
post #8 of 16 Old 09-02-2014, 08:33 PM
YJ4LIFE
TJ tank?
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline
post #9 of 16 Old 09-02-2014, 10:28 PM
Randonexplosion
Deplorable
You're gonna use the stock YJ lines? The Vortec system needs a 3/8 supply and 5/16 return. Stock YJ is only 5/16 and 1/4 from all the other YJ builds I've seen.
post #10 of 16 Old 09-03-2014, 06:51 AM
Que89YJ
You can use the poly tank from any 91/95 fuel injected YJ with a regulator that has a return. Easy and cheap. The tank is a bolt in and the pump runs with enough capacity and pressure. The pumps are 60/70 psi which is exactly what you need.
Que89YJ is offline
post #11 of 16 Old 09-03-2014, 02:52 PM
95YJLS
Whoops, I missed that. In that case, I'll reuse the 5/16 and plumb in a new 3/8 supply.
95YJLS is offline
post #12 of 16 Old 09-03-2014, 04:24 PM
Randonexplosion
Deplorable
Thats what I did
post #13 of 16 Old 09-04-2014, 08:23 PM Thread Starter
clubtahoe
good replies i appreciate it I'm looking at all the options. Want this jeep on the trails soon. Thanks!
post #14 of 16 Old 09-04-2014, 08:26 PM Thread Starter
clubtahoe
Randonexplosion yeah I'm changing the line I'm looking for a in tank pump, probably going to get rid of my existing tank from 1990 going to a mid 90's tank so i can put a walboro 255 in it. not a fan of external pumps
post #15 of 16 Old 09-05-2014, 08:43 AM
Randonexplosion
Deplorable
If you have the poly tank you should be fine, the only difference from -90,91+ is the sending unit/pump. I just picked up a 91+ sending unit and pump and dropped it in.
