90 YJ back with the gremlins. - Page 2 - JeepForum.com
post #16 of 26 Old 11-11-2013, 06:36 PM
Que89YJ
Are you sure you don't want to do a harness replacement?
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #17 of 26 Old 11-11-2013, 06:41 PM Thread Starter
boatsandhose
That's what I was debating. What are your suggestions?
90 YJ locked f/r 37s d30 F8.8
boatsandhose is offline
post #18 of 26 Old 11-11-2013, 08:01 PM
Que89YJ
You are miss wired to the starter solenoid.
Fault codes:
No Start:
Que89YJ is offline
post #19 of 26 Old 11-11-2013, 08:05 PM
Que89YJ
He will have a harness:
The starter solenoid doesn't explain the blower though. That is the ignition switch.
http://www.cfoffroad.com/
Que89YJ is offline
post #20 of 26 Old 11-11-2013, 08:21 PM Thread Starter
boatsandhose
Huh? I replaced it this summer and I thought I put it back how it was supposed to be but there was a lot of bsing flying around so I very well could have screwed it up. Too cold to investigate but I ran out and snapped some pics.
post #21 of 26 Old 11-11-2013, 08:50 PM
Que89YJ
Don't you have the square one on the firewall?
Que89YJ is offline
post #22 of 26 Old 11-12-2013, 04:08 PM Thread Starter
boatsandhose
I have a relay, but the solenoid is mounted on the starter itself.
post #23 of 26 Old 11-12-2013, 07:34 PM Thread Starter
boatsandhose
The fusible link is 18 gauge/green per my FSM. I assume the other end is supposed to be on the relay with a 3/8" looper like all the other 4 or so ones?
post #24 of 26 Old 11-13-2013, 05:40 AM
Que89YJ
Yep, where were the wires you replaced? What circuit was it? The blower is switched ignition so the issue must be with the ignition circuit.
Que89YJ is offline
post #25 of 26 Old 11-13-2013, 10:33 AM Thread Starter
boatsandhose
The yellow wire going down to my starter that joins into two across into the bulkhead connector and another that goes under neath the dash through that harness eventually reaching the ECU. Luckily I pulled the ECU and there appears to be no damage there. There are some wires that melted from the heat of the yellow ones and are conjoined and I assume they are the ignition switch and blower. Just picked up another fuse link. No one in town had any green ones so I picked up a blue one but it is 18 gauge so should I tag it with something or mark it for future reference?
post #26 of 26 Old 11-13-2013, 11:17 AM
Que89YJ
I still dont get how that harness cooked without taking out a fuse or a fuseable link. Contrary to belief the whole point on a fuse is to protect the wiring not the electronics and yours definitely failed. You have me concerned because I am setup the same way as you with the 2.5L. I have a fuse box to replace the fuseable links ready to install, but the way yours fail would mean that something else needs to be changed to be protected. Here is a link to the pdf so you can search the wire colors to figure out the circuits. It might help speed things up on your repair. That yellow wire goes everywhere!
http://dl.dropbox.com/u/40590346/87-88%20YJ%20Jeep%20Wrangler%20FSM%20manual.pdf
http://dl.dropbox.com/u/40590346/1990%20Jeep%20Factory%20Service%20Manual.pdf
Que89YJ is offline
