90 YJ back with the gremlins. - JeepForum.com
post #1 of 26 Old 11-05-2013, 07:08 PM Thread Starter
boatsandhose
Had some troubles before, thought it was good, but now I'm back scratching my head.
There are 3 wires that fried when I tried to start it the other day:
-One underneath the battery tray that got trail repaired with the only wire we had; 18 gauge speaker wire. I've already replaced that one with 12 gauge.
-One that goes from the ECU, out the firewall, along the harness and down under the battery tray and I believe connects to the starter solenoid.
-One that goes from the junk under the battery tray along the harness and clear over to a pin on the bulkhead connector.
Having troubles diagnosing this one. I have a hunch it was one of the wires on the solenoid that wasn't connected all the way and was arcing. The nut on the wire wasn't super loose, but wasn't very tight.
Right now I'm attempting to replace these wires but am having trouble pulling the pin out of the bulkhead. Is there a special tool for this?
Here are some pics:
Any help is appreciated, thanks!
90 YJ locked f/r 37s d30 F8.8
boatsandhose is offline
post #2 of 26 Old 11-06-2013, 03:02 AM Thread Starter
boatsandhose
Bump
Sent from my Galaxy Nexus
post #3 of 26 Old 11-06-2013, 05:52 AM
Que89YJ
I think this is what you are looking for:
http://www.jeepforum.com/forum/f12/r...d-pins-940109/
I would make sure you have the problem nailed down. That is because of a dead short not a loose terminal.
Que89YJ is offline
post #4 of 26 Old 11-06-2013, 07:53 AM Thread Starter
boatsandhose
Thanks. I do have that blue "lock" thing on mine so I'll play with that. What is the best way to find the dead short?
post #5 of 26 Old 11-06-2013, 09:01 AM
Que89YJ
Do you have a multimeter? You need to be able to measure resistance to find out what went wrong. If you dont have one they are cheap enough. HF and Radio Shack have them for $20 or so.
Que89YJ is offline
post #6 of 26 Old 11-06-2013, 09:22 AM Thread Starter
boatsandhose
I do have a multimeter. Should I check it at the bulkhead?
post #7 of 26 Old 11-06-2013, 09:52 AM
Que89YJ
Yes. Disconnect the battery lead and see if you have a short from that line.
Que89YJ is offline
post #8 of 26 Old 11-06-2013, 11:38 AM Thread Starter
boatsandhose
Ok thanks I'll go at it today and post what I find out.
post #9 of 26 Old 11-06-2013, 04:03 PM Thread Starter
boatsandhose
Was able to get the lock out, but I can't get the pin out. Pushing down on the top of the pin and pull the wire right?
post #10 of 26 Old 11-06-2013, 05:44 PM
Que89YJ
Yes
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #11 of 26 Old 11-06-2013, 05:45 PM
Que89YJ
You have to disconnect it from the firewall
Fault codes:
No Start:
Que89YJ is offline
post #12 of 26 Old 11-06-2013, 05:56 PM Thread Starter
boatsandhose
The bulkhead is disconnected from the firewall.
post #13 of 26 Old 11-06-2013, 07:11 PM
Que89YJ
Then it should pull out of the back of the detent is being pushed back when you are pulling on it.
Fault codes:
No Start:
Que89YJ is offline
post #14 of 26 Old 11-10-2013, 09:41 AM Thread Starter
boatsandhose
Anybody know how to remove the harness from the ECU? I've removed the glovebox and the two mounting screws for the ECU.
post #15 of 26 Old 11-11-2013, 05:44 PM Thread Starter
boatsandhose
Okay got the 3 burnt wires rewired, turned the key and it fired right up. It doesn't turn off when I turn the key and the blower motor runs whenever the negative cable is connected. After it ran for maybe 15 seconds I disconnected the negative cable and it won't start anymore. There are a couple of wires that got burnt that are underneath the dash that I need to replace and am having a hard time tracing them home. My FSM isn't telling me much. Near the mess underneath the battery tray there is a red wire with a white tracer that goes into a fusible link and comes out green on the other side. I can't figure out where it is supposed to go to as it is all melted away. Anyone have any idea?
